AntonyG
E30 Track capable pads
Hey guys & girls,
Im going to taupo in a few weeks with my dirty30 325i.
Any of you E30 owners or race series guys have
any advice on pads to use on the track?? I dont want to waste
my hard earned coin so some advice on what REALLY works
would be greatly appreciated.
Thanks heaps,
Antz
good condition OEM stock pads and discs. make sure your brake ducting is hooked up.
stock stuff in good nick is pretty much more than adequate on a stock 325...i ran mostly stock and it worked really well. i wouldnt bother with race brakes stuff, its good but quite expensive (when compared to upgrading to wilwoods, which is a better option)
Gus has obviously been smoking camel dung for his birthday.
A decent set of pads are far better than the pagid's that come on the car.
As to Wilwood, no doubt a better set up. But rotors, calipers, pads, fitting and compliance costs come nowhere near, just fitting better pads.
true, race brakes full set of discs, pads and fluid is well over a grand...the willwood full setup prob costs another 5-700 INStalled...which for how much your getting is good. Better race pads on the front arent a bad idea, I have just found the stock stuff to work fine (including puke)
Yeah, I'm with you Gus, we have race pads on one car and std BMW on the other, both E30 318's, and don't feel a lot of difference to be honest. Maybe to do with the cars being reasonably light, and having pretty efficient brakes anyway?
True.. so no ones recommending the EBC pads??
So genuine BMW 325i pads are the way to go?
Willwoods??? Pfft to that, its a stock M20. Not that
powerful
If genuine pads work at Pukie im sure they will be sweet at
Taupo as I thought Pukie was hard on brakes?
Thanks guys, I'll grab some genuine pads on Monday.
Its got near new Lucas pads in there at the moment,
I suppose their probably rubbish?
Puke is hard on pads..my setup was new pads/discs/stainless lines, slotted front discs and fresh fluid. you should do fine with new BMW pads, most aftermarket stuff tends to be crap
We have red ebc's in one car, but at 4 x the cost, they don't seem that much better? In saying that, they do stop the car slightly better I think, but hard to really measure.
I agree with the others - stock car, stock brakes.
RE the race pads - they just last longer and don't seem to fade is all I've noticed.
Thats what im worried about, but I will grab some genuine
pads and see what happens.
Cheers people :)
Yep, I had stock pads on my E36 328i and the first thing that failed was the fluid. So go and change the fluid first and take it from there.
I was itchy and did the whole lot.
Now all she does is squeal like a virgin.
:0
Awesome! I change all my fluids except coolant every 6 months so its
pretty fresh. Cheers
If you are going to track the car regularly. You should go for the braided brake lines.
Not have taken a little, light-weight car to the track. The Race pads have never faded on me, unlike the OEM pads. The OEM ones are fine if you are only doing 5 odd laps at a time.
I have Brembo vented slotted rotors on the rear, and I wouldn't do that again. The standard car rotors are excellent.
I don't remember my Mintex pads being significantly more expensive than the OEM ones. But they have lasted me nearly 4 years of road driving and the odd track day.
You should be considering "return on investment", not cost.
Edited by Cain
For what its worth i have run Hawke pads front and rear with new genuine discs. This stops the best i have ever had and no brake fade after a days testing at Puke. You pay for what you get. Why go cheap on brakes when you nedd to stop in a hurry you want to relay on what you got.
