Viking
E30 Electronics
I've just been informed of a cheap E30 320 manual going locally, not sure if its worth looking at. Most people who do the M50 converison use 325's but I was wondering if going from a 320 would still be the same. How much different are the wiring harnesses between a 320/325? Do they use the same harness just different ECU or chip?
If your doing a m50 conversion the engine wiring loom & ecu get tossed anyway.You just need to make wiring adaptor to meet the chassis loom plug next to the fuse box(pre facelift) or on the firewall plug (facelift cars).The wiring looms on all e30 are very similar with usually only the shape of some plugs changing over time
