Munts316i 0 Report post Posted September 25, 2007 While painting the undie van this year i seem to have got some little black dots from spray can overspray on my white beemer. any advice on how to take it off? the buffer is at home in the north island. is a professional valet the best idea? Cheers Alistair Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted September 25, 2007 While painting the undie van this year i seem to have got some little black dots from spray can overspray on my white beemer. any advice on how to take it off? the buffer is at home in the north island. is a professional valet the best idea? Cheers Alistair Thinners? Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted September 25, 2007 cut n polish ? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted September 25, 2007 Careful with thinners, can damage the clear coat. Would try cut and polish myself? Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted September 25, 2007 pwned, go pro. they will whip that sh*t off real quick, even your local panel and pain/t shop will set you right Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted September 26, 2007 Can try a clay bar first before any cut polish. 2000 grit wet sanding is another idea. Need a polish after that though. Otherwise, if there's only a few dots, the you can try to scrape the overspray **VERY CAREFULLY** with a blade. Quote Share this post Link to post Share on other sites
Munts316i 0 Report post Posted September 30, 2007 cheers for the advice guys Quote Share this post Link to post Share on other sites
m_power 0 Report post Posted September 30, 2007 Im a groomer part time, we use a product called "prepare it" most painters use it as well. But its a commercial product not too sure if you can get it at any old place. Quote Share this post Link to post Share on other sites
joel 0 Report post Posted September 30, 2007 Can try a clay bar first before any cut polish. 2000 grit wet sanding is another idea. Need a polish after that though. Otherwise, if there's only a few dots, the you can try to scrape the overspray **VERY CAREFULLY** with a blade. Where can you buy clay bars from?? Quote Share this post Link to post Share on other sites
jjs 60 Report post Posted September 30, 2007 Its good to see karma has come to get you after destroying my beautiful city!!! Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted September 30, 2007 Where can you buy clay bars from??repco etc Quote Share this post Link to post Share on other sites
