Tbirdsteve
M20 B25 pistons
Anyone know if I can replace my melted/collapsed 1990 M20 pistons with ones from a 1986 M20?
I don't want to buy the short block they're in only to find the tops of the pistons are different.
Thanks in advance
Steve
Guest Andrew
I'm gonna say yes - as long as the displacement is the same in the motor..
a set of oversize 83mm pistons for a 325 is only 1200 bucks... hah.
Look at the bore and the stroke and the ring type + crown type and if they all = each other then yes I would say
