pureboiracer 0 Report post Posted February 17, 2008 hey guys. was just curiouse if anyone has attempted putting a supercharger off the old levins onto a e30. and weather there would be a great deal of work involed and how well it would function in the end?? Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted February 17, 2008 (edited) On what motor? SC12 from the 4agze will probably be too small for any 6cyl. Id atleast try and get a SC14 from the 1GGZE, I believe the came in crowns, or something like that. Edited February 17, 2008 by Mike Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted February 17, 2008 Like Mike said a SC12 will be to small. Ive seen one a red e30 325 here in NZ done with an m20 and a SC14, was pretty cool Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted February 17, 2008 any idea of how much fabrication would be involved? Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted February 18, 2008 A reasonable amount, though not as bad as turbo. mainly mounts, pulleys and some plumbing off the top of my head. If your seriously considering doing this it seems as though you'll need to do a whole lot more research. Buy a book or start reading lots of websites. One of those things, if you gotta ask it probably isnt for you. Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted February 18, 2008 Lots of info in the supercharging forum at e30tech. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted February 18, 2008 yeh ive never had any dealing with superchargers before so do not know a great deal about them but i figure the only way to learn is to jump in the deep end and give it ago. its only an idea at the moment. not knowing alot about superchargers im asuming i will only need to make some mounts for it and run the air pipes and make a pully for it correct? Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted February 18, 2008 there is a red mtech2 one in auckland it was on trademe a year or so ago fro 8000....track it down its awesome!! Quote Share this post Link to post Share on other sites
M325is 0 Report post Posted February 18, 2008 I think Simon owns/use to own the red E30 your talking about. Havent spoken to him for a bit. For all I know he didnt do too much modifying and it was mechanic friendly. Think he got it done at A1 in Howick. Didnt take too long and wasn't as expensive as you would have thought. Think about $5000 all up. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted February 18, 2008 does the sc14 run an oil feed from the engine or does it contain its own oil like the sc12????? Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted February 18, 2008 Engine Management Would be the fun part... Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted February 18, 2008 (edited) ^ it would probably be run on quite a low boost so you could get away with a rising rate fuel pressure reg and bigger injectors, not ideal but would still do the job. combine that with a chip from TCD or Ant designed for boost (I'm assuming they can do SC chips too) and that should be fine for 7psi or so. Edited February 18, 2008 by Mike Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted February 19, 2008 what boost would you be able to run without pissing round with engine management? Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted February 19, 2008 No more than around 7-8lbs id say, thats with a modded eprom chip Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted February 19, 2008 Would be a cool project Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted February 20, 2008 I would look at running an Eaton M45 system off a C-Class Mercedes. You’d need to fabricate a few bits and bobs like the throttle linkage, drive pully, Supercharger mount and pipes but it wouldn’t be too hard. To make it all work nicely I would get a piggy back ECU installed and tuned. Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted February 20, 2008 This is what I ran on my old car. Note the throttle on the intake side controlled the charger, the pipe coming out the side of the charger goes down to a front mount and comes back up the other side into the intake. It would obviously have to be switched around on a M20. Quote Share this post Link to post Share on other sites
togate 0 Report post Posted February 20, 2008 this is the red supercharged one, was a weapon!! Quote Share this post Link to post Share on other sites
togate 0 Report post Posted February 20, 2008 oh looking at it closely now its a PFL with an mtech2...cool Quote Share this post Link to post Share on other sites
tire 10 Report post Posted February 20, 2008 E30's are great in red! Quote Share this post Link to post Share on other sites
isnowi 0 Report post Posted February 20, 2008 I would look at running an Eaton M45 system off a C-Class Mercedes. You’d need to fabricate a few bits and bobs like the throttle linkage, drive pully, Supercharger mount and pipes but it wouldn’t be too hard. To make it all work nicely I would get a piggy back ECU installed and tuned.This is the charger that downing atlanta use for their e36 m42/m43 kit, seems to be well matched, they run low boost with nothing more than a FPR and bigger injectors, somewhere i found a AFR map from one of their cars, was suprisingly smooth.Cheers. Dan Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted February 20, 2008 oh looking at it closely now its a PFL with an mtech2...cool good job aye! i wonder where that car is now??? Quote Share this post Link to post Share on other sites
togate 0 Report post Posted February 20, 2008 (edited) yeh its very clean. its still in auckland i saw it in G.I last year. sounds so so tough!....makes me want to buy another e30 now... Edited February 20, 2008 by togate Quote Share this post Link to post Share on other sites
no_fat_chicks 1 Report post Posted February 20, 2008 (edited) Man, I remember this car. I nearly bought it, I had the money for it as well back then (2005). What put me off was his mate, he told me that the car had already been crashed 3 times. Now, I regret not buying it. Edited February 20, 2008 by no_fat_chicks Quote Share this post Link to post Share on other sites
matwithe30 0 Report post Posted February 21, 2008 would be a very cool project...in england a dude put an m90 longnosed supercharger out of a jag onto his touring. looking amazing Quote Share this post Link to post Share on other sites
