Creaver
schnitzer wheels
Yep, only native to E46, E36, others need spacers at least, not sure on hubcentric rings?
FYI they're reps too... not sure if you're fussy about genuine ones though.
Also, if they're made for E36/E46, the wheel width might also be a problem on the big 5 series.
Wasn't really after them, just typed Schnitzer into trademe and these popped up. I am however after schnitzer type II's?? The ones with 5 large spokes, similar to the ones on Arros's e34.
The ones on Arro's E34 are also reps I believe. They were made by Advanti. My wheels are a similar style called the "Essen" I'm not sure if the 5 series version had the same name.
They do pop up on Trademe every now and then, should only sting you a few hundred bucks for a set.
