piriaka
E 39 Heater Fan stopped!
Hi
help!! can anyone advise what might be the problem - my heater fan has ceased to function. Was going and now, does not. Any advice? Any tricks?
Thanks heaps
Regards
Either ignition switch or heater fan resistor block. You need to check systems voltage at the violet wire on the back of the ignition switch. If you have systems voltage there and systems voltage at fuse 41 in the glovebox it will be the resistor block
Thanks, Glenn - right on the money mate. BMW dealer confrims that it is the heater fan resistor block.
I appreciate your advice.
Regards
Ray
Regards
Ray
Ouch!! not cheap! Realitively common problem though
