e30guydownunder
E30guydownunder's Track Hack, M42 + E85 + Boost
Hey guys thought I may as well start my own thread. Been mentioning it a bit in other people's thread so here is my own for you to ask all your questions and talk sh*t about some drunken Aussie attempting to go racing on the other half of my poor ass student budget :)
I think what I will do is Give you a rough story on where its all at currently. Then the rest of the background info nd then we'll carry on from there.
Currently the car has a 300k M42 in it, with a Markd Chip and is making 100hp at the wheels. Nothing fanncy but when there isn't much weight to cart around it gets moving alright. I have a fairly cheap suspension setup but it is definitely working for me. And here are some recent pictures:
Posted Image
Posted Image
Posted Image
Then for some retarded reason I figured I wanted more power? The natural progression I guess. So I have embarked on a turbo conversion. But nothing is ever simple. So I decided I would move the engine back about 95mm to help with weight dsitribution and then I decided I would do this and do that etc etc. Here's a few photo's to show where that has got to.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
By this stage I was getting a bit worn down and time was running out for getting the turbo up and running for the new season. Then I made this mistake:
Posted Image
At which point I have sin binned all the turbo bits for a little while :) Having just done my first track day in four months I am full of renewed enthusiasm to get it all happening again, but right now I am going to focus on a few suspension issues and uni has started up again, so I have to concerntrate on that as well.
That will do for tonight, more to come :)
Alrighty so I came to the decision a 318i wasn't for me and upgraded to a 318iS. The new baby came with some 17" chromie shite that I couldn't dump fast enough. In the process I picked up a set of MIM 1900 wheels off a nice local bloke. We got a bit to talking and he mentioned how he was going to embark on a RHD conversion for his newly purchased M3 and that his track hack 325 was going to donate the critical brackets and firewall pieces. I had a quick look and couldn't believe how good a condition this "rust bucket" of a thrashed and "worn out" 325 I was looking at. We struck up a deal and I got a straight 325 shell and he got the front half of the bent 318iS (bought at auction for some front end panels...lil 318i had a stack :unsure:) kicking round I had. This 318iS kindly donated it's running gear to the cause and I was now well on my way to having that pipe dream racing E30.
The 325 roller:
Posted Image
Posted Image
Posted Image
All pretty typical really. The bent shell from which I took the critical peices:
Posted Image
Posted Image
Posted Image
Alright lets get cracking on removing stuff!
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
And that about covers all that went on with shell, before the rollcage and rest of this silly business. I ended up getting about 8kgs of insulation off the underside....pretty piss poor when you consider I spent three days attacking it with an angle griver and wire wheel attachment :wacko:
Edited by e30guydownunder
Guest Simon*
Hey Chris!
Cool project. There's a lot of sentimental affinity here for Turboed M42's - one particularly badass red one passed through many hands in the past.
Has the blue bracket frame been fabbed up to allow the block to sit further back?
There seems to be some issues with linking your later images or something of that nature.
The only post with pictures in it is the first one. I just booked the other posts for when I feel like adding the essay and appropriate pictures :) If there is an issue in the first post I can't see at the moment so will have a look later.
The Blue Frame is a front cut. Or if you were talking about the RHS on the front of the engine that was used to position the crank. The engine has been moved backwards 95mm and rotated clockwise 10-15degrees.
Hopefully at some point this shall be a badass turbo'd M42 but I think the turbo is a bit small to allow that currently. Its a GT2560R and should just be able to squeeze out a bit over 200hp at the wheels. Will be nice and responsive though :) and has many bigger bolt in brothers GT2871 etc
Very cool, follow this on e30tech a bit, will be a little monster when its done :)
Alright guys. I have a confession.
1) updates are long over due, for that I appologise
2) I gave up!
The M42 was getting too expensive and taking too long. But before we get to the meat of the story. Some background work that was happening regardless!
A Brake Upgrade, front and rear are now ventilated. F: 280x24mm, 2 piston WRX Caliper, R: 270x19mm, Single Piston WRX Caliper. These calipers were free.
Posted Image
Posted Image
Painted some Stuff:
Posted Image
Welded some stuff
Posted Image
more painting of stuff
Posted Image
Oh what a large drivetrain you have there in your E30:
Posted Image
The Gearbox is out of a 300ZX, but don't be fooled it ain't got a VG in there. Nope this now has an SR20, tractor engine I know, but you can't beat the price of these things. Dollar for Power I don't know what beats it. Apparently the Mitsubishi stuff is cheap too, but a RWD box is much harder to come across for those!
ANYWAY, So I've gone and stuck an SR in the thing. Since then I have basically ahd to rework the whole setup!
I believe the first engine suffered some oil starvation at the hands of theprevious owner. Use was promtply stopped, the car sat around for a while, then he got the bright idea to sell it all!
I came across a "350whp SR20, gearbox and everything package" sweet I though, I was currently going through a bit of depression with the whole E30 project and life in general so this seemed like the answer. I had a track day in 4 weeks time and purchased an SR20. I then proceeded to bust my balls and also enlisted the help of my father, brother and a few mates. It was an all hands on deck effort to get this thing there.
Then to go to the Dyno the day before the track day and have the engine drop shits its pants about an hour into tuning and not even one proper power run on the board was a bit heart breaking. BUT, thats racing right! No pain no gain.
Some pics:
Intercooler mounted
Posted Image
Cold pipe
Posted Image
Dump pipe
Posted Image
New shifter location
Posted Image
Heater and turbo water cooling delete
Posted Image
We modified the position of the wastegate and then made up a screamer pipe :)
Posted Image
Heading off for the disappointment unknowning!
Posted Image
On the Dyno:
Posted Image
Alright so I picked myself up, bought an S13 and stripped it of its SR then sold it.
Posted Image
Posted Image
The New engine is pretty stout:
Arias forged pistons
Eagle rods w/ ARP2000 Bolts
Balanced
New oil pump
Ported and Polished head (only minor work)
HKS stage 2 272 exhaust cam , and 264 intake cam
HKS Valve Springs
HKS Rocker Arm Stoppers
new timing chain
all new gasket incl Metal head gasket with Cap screws holding it down :)
The cams were removed as it was suspected they were the source of a noise. I'm now no longer convinced this is the case and may reinstalled them yet.
SOME MORE BASTARDRY:
One thing that struck us as odd was how the Z32 conversion had been carried out. There were only 4 bolts holding the gearbox on! And non were across the bottom! Have since worked out this has stuffed the twin plate clutch that it was fitted with. But in any case. We have taken the time and made provisions in the Sump for some extra bolts to come through the gearbox!
Posted Image
SOOO BRING ON ROUND 2
So the new engine has been in and going for a lil while now. The setup has been changed further though. The turbo was f**ked.
So I bought a standard manifold and TD06SL2 (the turbine is a bit smaller than TD06H) with a nissan turbine housing setup. this means internal gate.
I modified my dump pipe to suit, hooked up water cooling lines also and was happy with progress:
Posted Image
Nearly ready to go off to the dyno:
Posted Image
Some heatshields and sh*t:
Posted Image
Posted Image
That was last Thursday night. Found out we have some overboosting problems. So we set it up with buggerall ignition where necessary and pretty rich and came home with 243whp @ 6300rpm. An a calculated 450Nm from a touch over 3000rpm to 6000.
But f**k it I'm going to this trackday! Dad had Friday off to try and finish the car and I cam home from work and we ended up staying home the night (normally head down the day before an event at Wakefield). We were all loaded up by 1030 and ready to go.
Overheating, Boostcut issues aside I still knocked out a 1:10.8 and was happy with that. I wanted to go home with a 10 in the bag. More importantly I came home with the car in one piece and know we are only going forwards. There is probably an easy 2 seconds left in the car once I have the overheating and overboosting issues sorted.
I've already ordered some piping to make brake ducting so that should see an improvement in that department.
There are a few contributing factors to the overheating so we are going to tackle these before returning to the dyno, controlling the boost and dialling in some ignition for some more power. NOT THAT it needs it.
The car is still incredibly easy and nice to drive. It's very well balanced and doesn't sit around spinning the wheels or anything silly. It just gets down and goes. I'm very happy with the throttle response and way the turbo comes on. Basically it goes hard!
Get these issues sorted, drive it and watch the times tumble :)
Here is a picture of the new front bumper we fitted as part of the conversion.
Posted Image
All important Side pipe!
Posted Image
Alright So I'm back from the track and we have had a sit and a think about it all. Very happy with how the car is and how it performed first event out.
I'm aiming for a trackday October long weekend (first weekend). The job list is fair but modest.
Things that will happen:
Turbo setup removed. Wastegate Flapper Fixed, Manifold ported to match head
- Test, if boost is controllable - TUNE
- if boost uncontrolled still, add my external gate.
Diff will come out and my 4 Diff Plate centre with more preload will be going in, new bearings seals etc.
CV's will be stripped, reassembled with new grease and boots (assuming nothing looks particularly wrong)
Brake Ducts made and fitted
Front Splitter made and fitted to front bar - incorporating substancial radiator ducting
Maybe List
Throw the HKS cams back in
tidy the interior more - wiring is still a bit of a mess
CAN communication between Dash and ECU
I like your style, serious motivation..boost ;) hah
Reading these builds makes me want a track thrasher so bad!
Must, resist...
Thanks Mate.
It was a struggle towards the end there, but now that I have got it there and driven the thing I'm much happier! I have some uni work I am trying to sort out, but hopefully will get stuck into fixing up the few problems I have and make some progress towards getting some back to back laps!
The car is showing so much potential, I want to up the anty on the aero but I love the understated look currently. I'm definitely fitting a front splitter, but a Rear wing would get me some serious time at Eastern Creek with all the high speed corners.
Here are a few pics from the event I found on the net:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
I have fixed the SR for good.
Back to old faithful M42......but now with proper boost.
1383327_10151614436117100_777108802_n.jp
Better pics and such when I have time, busy preparing it for the Mattara Hillclimb this October long weekend. I am running in the club day event on the Monday because all my mates are but anyway.
So Basic Specs:
BMW M42 (1.8L 4 Cylinder)
CP Pistons
ARP Rod Bolts, Main Studs, Oversize Headstuds
O-ringed Head and Block, Copper Headgasket
Cat Cams, VAC Motorsport Springs and Retainers
Custom Rear Sump
Garret GT3076R, 0.63 Rear Housing, Tial MVR 44 on custom Manifold
DTA S60 still running the show
Fuel Cell, 2 x 044's, 1600 Bosch Injectors and a bunch of other supporting mods.
I have changed to a Getrag G260 (325i trans) overdrive transmission and a 3.46 rear end, this is good for a touch over 200 in 4th and should mean I don't have to change to 5th at Wakefield.
There has been a whole pile of background developments but they are for later. Right now I am going to drive the wheels off this thing and put the development program on hold, I am well sick of wrenching.
__________________________________________________ _______________
Made it through the first event not without drama but I made it!
-coming home from scrut Thursday night got a flat tyre on the trailer (not so fun)
- Friday morning same wheel feel off trailer, broken stub axle!
- Monday morning rip exhaust off car trying to get off borrowed trailer. Got it patched up just in time for first run.
- Second run intercooler pipe comes off, hmmm did that on dyno, reassemble should be sweet.
- Third run, nope off it goes again.
- Fourth run all apples, rigged up some dodgy tie straps to the inlet.
Obviously this turbo setup was never going to be super awesome for a Hillclimb, add in that I had installed a 3.46 diff to suit Wakefield and Eastern Creek and it wasn't super pleasant. But I am pleased to have had a day out, simple easy to fix dramas and it came home straight and ready to go again, more than can be said for a number of cars that were competing also.
Got some sweet pics too :)
1377278_10151886442842305_1175523956_n.j
1382130_10151886441667305_1122595319_n.j
1375220_10151886441912305_1465578283_n.j
1186239_10201044862184233_1127126114_n.j
  • Like 2
Nice work Chris.
Where are the pics taken? Looks warm....
Fantastic photo's and build, good to see you are out doing it to it!
Nice work Chris.
The Hillclimb was run through King Edward Park, Bar Beach is in the background. Newcastle, NSW. It was a hell of a nice day.
Cheers.
