fatjoez
anyone able to flash/modify the computer?
My cars running aftermarket projector headlights with HID 35W kit replacing the standard 55W halogens
Been working fine, i installed some tiny LEDs replacing halogens which were acting as the daytime lights
now its throwing bulbout errors, based on what I've read / spoken to others, because the LEDs draw less power
Im sure its like less than 5watts difference cause those things are TINY
anyway is anyone able to change the computer settings so it accepts the new power level & stops throwing errors?
Where are you ?
I can help, but need to know where you are ????
hey man im in north shore, auckland forgot to mention
re: resistors I'm sort of keen to reflash rather than add resistors,
failing that I was considering another option which was adding some more LEDs on the bumper as additional daytime lights
which would hopefully increase the power consumption to the same/beyond the level it was with halogens & hopefully cancel the errors also
Edited by fatjoe
Get hold of Josh (Hybrid on here) he can reprogramme for you
Bit far from me then :)
Greg
Greg
lol yeah darn I noticed the Timaru in your profile haha
So you're confident it can be done then?
Easy job?
Btw I saw a post on an international forum about a guy in Germany who does custom coding,
like adding an option to show actual velocity in the dash electronically
you do things like that too / know anyone who can?
Posted Image
http://www.1addicts.com/forums/showthread.php?t=452070
Easy job?
Posted Image
Yes the bulb error is easily removed with software called Navcoder, written by BSport member Jochen.
It does not have the custom speed display feature though - I guess that involves some coding to read the speed from the speedo sensor and writing it to the MID - similar to what the DICE iPod interface does.
If you are keen, you can get a copy of Navcoder and build or buy the necesary interface and do it yourself
Navcoder Website
mad fun
hey question though, IBUS port that navcoder refers to,
is that the same as the OBD2 port which my car supposedly uses?
Its a 2009 Year car
IBUS = OBD2?
mad fun
Its a 2009 Year car
IBUS = OBD2?
No - the ibus is only for some units, mainly entertainment and dash
OBD2 port is more for diagnostics and reading and resetting of engine ECU errors etc - Navcoder is not that type of software, for OBD2 you need a GT1 or clone system.
Edited by camera doctor
Oh right I see
Is it possible to reset / recode via OBD2?
of course
that's the whole point of obd2: it's the diagnostic interface to allow to to recode the car and diagnose the car
yea sorry mate still a bit new to it
done the research and yea I see now that it is certainly possible to do almost anything with the OBD2 port
The main things I have read on other forums of people doing with it
- disable seatbelt light/sound
- recode lights for new LEDs
- add electronic speed to dashboard
- enable certain features previously disabled
now if I can just find someone who is able to do this!
no luck so far, no reply from josh (hybrid)
bump
still looking for someone who can do this
Currently in talks with Tom(M3_Power), though he's never done it before so trying to contact the german overseas who does this to try and get info on how to do it to pass onto Tom
Does *anyone* else have any info or know anyone in auckland who might be able to do this
It most certainly is possible as seen below
http://translate.google.com/translate?hl=e...en.html%231.5.5
what car is it?
u mentioned 2009 im pretty sure nothing that new runs ibus and therefore cant be used with navcoder?
bump
I'm currently in Auckland.
Whilst I have my software here, I didn't bring an interface woth me
Any standard OBDII KKL interface with a USB connector will work.
As for getting digital speed display on the dashboard, that is available as a standard diagnostic function on most BMW instrument clusters. No coding required.
Any turning off lamp warnings is easy, although my notes for that are at home (I need my notes if the car is a facelift E46)
Edited by jochen
Awesome well the car is a 2009 e82 135i coupe
M3 Power has an OBDII cable, would we be able to arrange something between the 3 of us?
I'd be happy to chip in with beers/bling whichever takes your fancy
heres the response i got from the car-coding.de guy
For your car you need at least a D-CAN OBD interface (for cars from 03/2007).
Concerning Software:
We will not distribute our own software because it was a huge effort to develop it and it is actually the basis of our buisness.
On some websites one can find software called NSC Expert and EDIABAS.
In conjunction with current coding data these tools are capable of doing the desired coding
so yea as per M3_Power, d-can
m3 is your obdII cable D-CAN???
jochen do you know how to use NCS Expert? I have a vague idea but have never actually used it.
Also I am suspecting that this will require both NCS and EDIABAS to work (one to recode and one to reset) Or perhaps EDIABAS can simply turn the bulb test off on its own??
Do you know if EDIABAS version 6.4.7 is used or 5.0.2?
fatjoe ... I've told you many times I have D-CAN and OBDII KKL - cable don't worry I have what's needed and most likely the software also but I just don't actually know which one is used and what function. If it's a recode I don't want to risk bricking your module (very easily done and you'll be a couple of thousand dollars down the drain if this happens).
Edited by M3_Power
big ups to M3_Power
was over at his place for a few hours today
very iffy software this NCS Expert
apparently only 1 bmw technician in NZ knows how to use it lol
ah well anyway long story short we fiddled around a bit and finally managed to read the ECU values from the car for the specific modules and disable one of the Bulb tests (hopefully the right one lol) and also managed to enable the digital speedo you can see in the previous page of this thread
sooo yea alls well that ends well!
will post back tomorrow when i do a cold start!
thanks again to M3_Power, Hybrid and everyone else who helped along the way
Edited by fatjoe
okey dokey then coldstart still sending bulb errors so I'm guessing the 1 sensor we disabled wasn't it
no biggy
The german guy who does this as a service helped me out with the correct sensors to disable for headlights
WARMUEBERWACHUNG_AL - warmtest low beam
WARMUEBERWACHUNG_BLK_V - warmtest flash/turn signal front
WARMUEBERWACHUNG_SL_V - warmtest park light
WARMCHECK_E89_FL__E7X_NSW
KALTUEBERWACHUNG_AL - coldtest low beam
KALTUEBERWACHUNG_BLK_V - coldtest flash/turn signal front
KALTUEBERWACHUNG_SL_V - coldtest park light
KALTCHECK_E89_FL__E7X_NSW
CC_MELDUNG_AL - notification lowbeam
CC_MELDUNG_BLK_V - notification flash/turn signal front
CC_MELDUNG_FL - notification park light
CC_MELDUNG_SL_V - notification park light
GUIDE
AL = Abblendlicht = low beam (front)
FL = Fernlicht = high beam (front)
SL_V = Standlicht vorn = parking light front
BLK_V = Blinker vorn = turn indicators front
keep ya'll posted
Seeing fatjoe hasn't updated this I thought I might.
We've successfully coded his module to not to cold start bulb check via NCS Expert (pretty cool tool actually once you get the hang of it).
So everything all hunky dory for his 135i.
Yeah i have it here, Although i have not been game enough to use it, As you said a couple back one small slip and the wrong value put in and you are up sh*t creek with ought a paddle.
