gmccormack
Big Block e30
Guest Andrew
hmm m30.. Gavin Bellars from bellars motorworks has a project going on. You could do your own engine mounting without mutiliating the firewall if you got an electric fan.
Guest Shadowliner
the 3.5 engine from a 635 will go well into it.
the bmw 333 is no other than the 3.5 engine in it.
lot's of torgue and if you force feed it,it will be devastating.
I've a seen a turbo 333 in action when I lived in SA and nothing touched it, I mean nothing not even it's bigger brother M3
Posted on Jan 26 2004, 08:26 AM
Did you ever see the 333I agianst the SA 325iS
Guest Streetspec_is
E30.de has heaps of info on the M30 swap..and you can buy some of the mounts thru them IIRC.
chrz, jake
