philk
Fuel Type? 91 95 98? Fuel Consumption
Hi
I'm interested in what has been used and the results.
I recently brought a 1997 540i M62
I have put 95 Octane in it but have been told that these can run on 91 well? as they were designed from factory to go to Japan and USA where they run a lower octane 87 and 89.
Is this true?
What would happen if you run it on 91 octane?
Also what is your fuel consumption like? km/l I get about 7km/l round town and a little bit of open road driving
I'm interested in ppl's comments on this thread also.
I always run 98 however there was a point where I was forced to use 95 because of location.
I can't say I noticed too much difference.
So I'd like to know what i'm paying for?
I have an NZ new manual E36 328is M-Sport M52 engine, 195k,
Mileage - 3174km - 95 octane with 1 x Envirotab Octane pill per fill
km - litre l/100k
546 41.26 7.55
568 45.9 8.08
476 39.14 8.22
529 46.6 8.81
600 48.77 8.13
455 39.74 8.73
32 to 38 mpg - includes track time
My 318 Compact always averaged 6.7 to 7.3 l/100km - driven hard
Pays to keep an eye on the figures,
Regards
Paul - E36
km - litre l/100k
546 41.26 7.55
568 45.9 8.08
476 39.14 8.22
529 46.6 8.81
600 48.77 8.13
455 39.74 8.73
Regards
Paul - E36
Great to hear
I should note what I put up is 7km/ltr which is about 14.2 ltr/100km (mixed driving)
I've never heard of the Envirotab I take it increase in octane? what is it like without it?
cheers
Edited by philk
http://www.envirotab.com/Home.htm
check the site, it does work, its more than just an octane thing - used it in 4x4 diesels and 3 x BMW's and certainly got better economy over not using it.
97 octane plus a pill IS noticeable !
Had a look at envirotab looks good, quite expensive I thought though?
Wonder if it pays off in fuel mileage for the 540. I may give it a go next pay day lol
I use 91 in my e34 540i for town driving, get around 14.4L/100km. Found using 98 made no difference for city driving.
i use 95 or 98 in mine but tbh notice no difference....yep 91 is fine according to the factory..must try it next fill
Hi
I understood Japan had higher Octane fuel generally. The US rating are NOT the same as here, their 89 is like 93 or 94. 87 is 91 or 92ish. They don't trnaslate exactly, but they use a different rating system.
A lot of manuals say you can use lower octane fuels, but usually it says you can lose power and economy by doing so. 1 tank isn't enough to compare, unless you reset adaptaions etc.
I only run the E39 on 95, but I had a 2004 Pulsar new, which I ran on 91 for 20,000Ks, getting about 450 kms a tank. The service manager at Nissan said my car was gutless, did I use 91 or 95? I changed to 95, and then got 600kms per tank! Also gained a lot of midrange torque from the more advanced timing.
Higher octane doesn't make more power in itself, but it allows more efficient running through more timing advance (better power) and leaner running (before knock occurs) on "complicated" engine management systems, because the higher octane is less likely to "knock".
I have a mate with a 540i Touring who gets better economy from 98 than 95, but he has a lead foot! He averages about 13.5 last I spoke to him - but drives Glenfield-ish to Silverdale each weekday.
7.7c per litre better? Cos that to me seems pretty pricy!
The US pumps display AKI (Anti Knock Index) which is also called "Pump Octane". AKI is (RON + MON) / 2.
RON is the research octane number, as displayed on pumps in NZ, and is obtained by a test under pretty favorable conditions. MON is motor octane number and is obtained by a test under tougher conditions that simulate higher load and hotter conditions. The MON test number is therefore quite a bit lower than RON.
AKI, being the average of RON and MON, is therefore a lower number than RON for the same fuel.
The MON is often about 9-10 octane numbers lower than RON, so as Allanw states above, the AKI comes out about 4-5 numbers lower. (Our 98 would probably sell 93 in the US).
To me that website absolutely screams snake oil. The wording on their "technical" page is pure marketing trite.
I'd avoid anything like this like the plague unless you see evidence of their claims performed on a proper metered test engine against testing standards by an independent test facility or university.
No difference here either. Probably because it's a big slug of an engine that's never (almost never) put under any high load.
ive used a range of different fuels in my e39 540i
generally havent noticed a change in economy
usually go for shell 95 as its a good price for the octane
bp98 if im going to drive it hard
have tried gull force 10 a few different times
seems to drive fine on it but everytime it goes in the car it gets a rough idle
as soon as i use another fuel the idle goes back to normal
Well here are my results so far
I tried 91 put $40 in was ok idled a little rough when cold economy was ok too, but not fantastic.
Tried the gull ethanol E85 felt good if giving it a bit, but very rough idle when cold and took ages to smooth out poor economy
Put $60 Mobil 95 nice smooth idle nice and responsive and good economy bar far the best so far.
Am going to try BP 98 and Gull force 10(98) and see how they go
I get about 9.5 km/ltr open road on the 95 around 7km/ltr round town
