winckel
How Many KM's has your car done?
Thought this would make for an interesting post:
Make and Model: E39 523i A SE
Issues during ownership: Radiator / Thermostat & Housing at 240,000, Shocks at 300,000, Starter, Cat Failed,
Current Milage:339,500KM
Mods: M5 subwoofer and amp under rear parcel tray. Business CD upgrade. Motorsport Suspention Package.
17" Staggered Fitment Motorsport Alloys. Cree LED angel eye bulbs.
Dice bluetooth kit. Valentine One hard wired. Hella HID retrofit kit. Euro Plates.
Work Required: Fitment of HID kit. (I have been hunting for this kit for a long time. I have hella lights with odd ball bulb adapters), Top hose has buldged, apart from that its magic. No leaks.
I'm also going to add that it has never had any suspension arms replaced. It still has its original upper arms in the rear.
I can only put this down to open road driving?
I am the second owner. Kiwi New.
Look forward to seeing your replies
Edited by Deli-Lama
Make and Model:1993 E36 M3
Issues during ownership: Complete Engine Rebuild, with Shrick Cams, JBR Steel Flywheel, Clutchmasters FX 100, UUC Evo 3 Kit, Bilstein Sport, H&R Sport.
Current Mileage:23?000kms, and 500kms since rebuild...
Make and Model: 2001 E39 525i Auto Motorsport
Issues during ownership: Radiator, Water pump, New engine/Auto software at 59,000
Work needed - Whistling noise when cold (don't know if this is a vacuum leak/Gearbox...I'm lost!!)
Current Milage:60,500KM
Edited by Garryg
Make and Model: 1994 E38 740i
Issues during ownership: Just waterpump, thermostat and expansion tank replacement plus a few bushes here and there
Work needed - Air bag light reset and horrible knocking when braking which was fixed then came back.
Current Milage:240,000km
Make and Model: 2002 E39 M5
Issues during ownership: Clutch slip, dead A/C resistor, broken headlight adjuster & warped front discs.
Work needed: - None it's peeeerrrrrfect.
Mods: LED lighting, 19" rims, SSK, slotted rotors, stoptech brakelines & uprated pads, aftermarket speaker upgrades, DICE Ipod, Strut Brace + H&R springs, front splitter, remus exhaust, GPS tracking, Clutchmaster clutch, k&n filters
Current Milage: 90,000km
I doubt anyone will beat 339k's Sam, wholey crap. that's amazing.
Edited by M5V8
Make and Model: 2004 E46 330i
Issues during ownership: Had it for ~7000kms and already had an oil leak (from the PO..) new rear tyres and now a broken power steering pump
Work needed - Still in getting the power steering fixed
Make and Model: BMW E36 Coupe 1993 325i
Issues during ownership: Not much went wrong in first 18 months of ownership just basic maintenance, M50B25 was not powerful enough so replaced it with a ~73,000km Lexus V8 1 year ago.
Work needed: Finish custom headers and exhaust, finish upgarding brakes and suspension to M3 gear, finish installing reinforcing plates, install strut bars, update engine/gearbox mounting brackets, install gearbox computer controller and momo steering wheel, paint bumpers and get certification. (lots!)
Current Mileage: 200,XXX kms
Make and Model: 1995 e38 740i
Issues during ownership: shocks, headlining, front susp arms, tie rod, leaking valve cover.
Work needed - shocks failed @240k km. failed warrant. suspension bushings failed and replaced.
Current Milage:280,000km
Make and Model: 1995 bmw 320i
Issues during ownership: radiator plastic crumbled - replaced with new one, plastic thermostat housing replaced 3 times in 3 years, headlining, Jatco trans, crank sensor - twice,
Work needed - waterpump therostat
Current Milage:290,000km
Edited by Docile
Make and Model: 1998 e39 540i
Issues during ownership: Previous owner had gearbox fail (pump seals) full front brake rebuild and thermostat
Work needed - front Thrust arm bushes need doing, random wear and tear items on interior, nothing major
Current Milage:186,000km
Ive a e30 with 384km so just sneaks past that.
make and model: e30 318i
repairs: replaced idle control valve and afm, slight rust in the boot. ran fine for a year and didnt have any issues
upgrades since buying: 2.8 6cyl, gearbox, diff, suspension, steering rack, brakes, bushes, m-sport seats, bunch more stuff
work needed: all the paint is sunburnt and the boot is pealing :(
25x,xxxks before i started, not sure now.
best and most reliable car i have ever owned
1992 E34 525i Touring
249,500.
Kiwi New, Genuine Towbar, Sunroofs(leak free! and working!), Gay Blue Interior. SLS (working!)
Repairs : ALL Vac hoses, Intake boot, ICV. Drivers window clips broke one day
Needed: Oil Level Sender Leaks, Rocker Gasket Leaks, Transmission needs a service... due for service at 250,000.
Heater core leaks(probably o-rings) all the Hatch wiring needs fixed, well most of it. Quite interested in doing a cooling system overhaul at the same time.
I love my touring allready :3
249,500.
Any nmore?? Come on this could be a great thread?
1985 E30 320i Manual Sedan
267000kms
NZ New, Sunroof, Towbar, Mtech 1 Steering wheel, almost complete toolkit
Repairs: Fuel Pump Relay, Front Wheel Bearing, Steering Rack, Steering Pump, Minor Rust Repairs
Needed: Service (overdue!), Thermostat(takes ages to warm up!), Seats re-covering, Paintjob, Oil Leaks
Got some sweet as Prorack roof racks for $5 as well, but saving them til I get a cycle carrier.
e21 323i NZ new sold at 119,000kms Issues , Poor engine earthstrap causing running issues , Cracked head (comon prob)
e30 323i NZ new sold at 337,000 kms, Issues , wear and tear , head gasket issue after hose came off after service @191k km
e36 318i sold at 120km Jacko auto transmission issues sorted under warranty
e36 325i nz new sold at 255,000 km, no issues.
e36 328i 155,000 km, fan resistor replaced, otherwise good
e46 M3 61,000km , No issues
Car 95 328i Manual Dunedin new, 4th owner for 3.5yrs and done 30,000kms, now at about 175,000kms
Issues- Icv hose popped off, broken wire to bootlid for reverse lights, broke a tooth off LSD spider gear (still havn't fixed and been fine for years). Door lock actuators, drivers outer door lever broke, Jammed igniton barrel.
Just done thermostat and alloy housing, waterpump and viscous fan for peace of mind
Vanos rebuild to do.
Upgraded to h&r's and bilstiens, LSD, 17" wheels, full custom exhaust with Remus, KnN filter, acs rear insert and rear window spoiler, colour matched bumpers and sills, yellow fogs, darkened headlights, halos, hid's (running norms till I get shields sorted) black grill, full 18 obc, tints, sounds and probally more
Car 96 318i touring manual also Dunedin new, ex demo, 2nd owner for about 3 months, 222,000kms
Issues, replaced worn drivebelts, outer ball joints on the way out, odd trim bits missing or broken, door lock actuators
Just done waterpump, thermostat with housing for peace of mind
Upgrades so far, jamex superlows, 18"x8 style 32s
Have a full Mkit and side moldings to fit, need mirrors to complete then tint to hide work gear
Edited by euroriffic
Simons (EX) 540 will have done more
Make and Model: 1994 E34 525i manual NZ New
Issues during ownership: Slave cylinder, UCAB's, rear shock mounts, front sway bar link (just one),door panels rattle, wipers hitting hood
Current Milage:257,500KM
Mods: Subwoofer and amp. Pioneer deh3450. Bilstiens shocks rear, jamex springs all round.
18" M-par Alloys. Whiteline rear sway and d-bushes.wrapped hood
Work Required:could always do with more petrol, will tweeters in the sails when a fine day comes around
I will put some billies in the front when a fine weekend comes around, and I might try those moosehead engineering bushes too
Just ticked it over to 130,000km's
Thrust arms - replaced
Complete cooling system overhaul
Replace pulleys and belt
Replace aux fan <_<
Things to do:
Replace rubber molding on windscreen
July 2011 Megane RS250 = 29,000km now. No issues other than it being on its third set of tyres very shortly, but that's a driver fault.
2006 Megane F1.R = 120,000km. Driven very hard. Only real fault was a bolt coming loose and breaking my flywheel, this was caused by poor workmanship from when I had the gearbox out to have the LSD installed. Overall very impressed with the reliability and durability of this car, it gets driven harder than your car and it loves it. So much for the stereotype.
1999 BMW 328ci. 135,000km. problem outside of servicing was the control arm bushes. Other than that it has been the most reliable car we have ever had! Up yours whoever coined them BW-Troubleyou?
1989 E32 735iL
93800km
Kiwi New, Genuine Towbar, Sunroofs(leak free! and working!), Gay Blue Interior, Sony Xplod all round - loud as!!
Repairs : Oil change, ICV cleaning, Spark plugs (orignials came out)
Needed: Wiper blades, Right hand side wiper arm missing plastic shielding, Sunroof control panel a bit loose, front pads low
To do list: Door handle seals, tints 35%, Exhaust system - euro tip and free flow mufflers (booked in)
Posted Image
My fuel consumption whilst doing 180k :D
https://fbcdn-sphotos-a.akamaihd.net/hphoto...627852372_o.jpg
Posted Image
3rd set??????? OMG
:blink:
I know <_<
The car doesn't really need to slow down for corners, you can go into most bends without slowing and if you do slow you can mash the gas on the apex and the LSD drags it out, its a lot of fun and very good at getting
along fast on back roads but it is getting very expensive at an average cost of $550 per tyre ($5500 a year) so I will be backing off on the corners on the next set as its becoming rather expensive... especially when you are buying two sets a year for the Targa car.
Looking at some alternative tyres with a higher tread wear rating also as a lot of the latest gen tyres are as soft as some semi slicks. Good Year Asymmetric II have a 300 rating and still perform well so will be hunting out a deal on them.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
