Michael.
What is E85 Gull Force Pro Fuel all about?
I just noticed this at a pump in the North Shore today. Didn't realise it was available other than at Hampton Downs.
Having read up about it there seems to be so much conflicting information on what cars it works with and doesn't due to the age of cars and these so called 'flexi-fuel' cars.
Some say it will eat 'regular' cars rubber fuel lines and seals, even lead to bad oiling etc but then others say it doesn't and brings many benefits despite increased consumption.
Same with the way cars are tuned, I gather its 110 octane? Clearly most NA cars wouldnt see the advantages of this unless having a higher than normal compression.
Curious to know who uses this fuel and for what applications?
Some American brand cars sold here are Flexfuel compatible. Dodge and Chrysler in particular. Those ones can use that E85 fuel without issue. You are right in the Ethanol does eat the rubber and seals and causing trouble in non-Flexfuel fuel system.
Sent from my iPad using Tapatalk
I use the E85 gull force pro fuel when doing track days / weekend fun runs :D
Pros
  • 45+HP and 90+Nm TQ over my 98 map
  • Cooling properties of Ethanol that helps with keeping temps down
  • How angry my car sounds + backfires /flames out of the exhaust :D
Cons
  • Few places in Auckland to get E85 at the pump (Hampton, Puke, Hillcrest)
  • Bugger all mileage
Don't run it normally for DD as I am lucky to get 300km out of a 60L tank verus my 550km usually on 98
  • Like 3
Can we hear it please.
It makes Evolution 9's sound like WW3 is going on in the forest. I love it!
So like an e90 m3 then? :P
lol but with a lot more HP/TQ then the m3 :D
  • Like 5
show us a full lap
Just interested in the breakdown of gull force pro
85% ethanol
15% fuel
Edited by Benji335i
Ethanol is a good fuel. It burns well, and cleanly, and in a car set up to use it, it is superior to unleaded fuel.
You do normally use more fuel when running ethanol than you would if using 'conventional' petrol. (There's another discussion about octane levels, energy delivered and heat, but we'll skip that for now.)
However, there are many different (synthetic) elastomers that are lumped into the category of "rubber" used in O-rings, seals and hoses. Two of these, most commonly used in motor vehicles, and which do not significantly deteriorate with petrol exposure, are Buna and Viton. Viton is more expensive. Buna can deteriorate with heat  while Viton is more resilient. Viton also survives exposure to Ethyl Alcohol, while Buna does not.
Care to guess which material was most widely used by the motor industry?
Typically, the biggest issue isn't elastomer (rubber) deterioration - it is the cleaning effect of ethanol that causes problems, exacerbated by old hoses which should probably be replaced anyway. These things do have a limited lifespan, after all.
Thanks mate for the explanation.
upgrading my LPFP and having an ethanol sensor and analyser installed with new lines from the tank to the HPFP.
i ideally wanna do E50 but is it easily purchased?
