E36MSport
BBS RK's on E36
Just had the option of a set of 4x 18x8.5" BBS RK's ET39. Anyone know if these will fit well on an E36 and what the recommended tyre size would be? Getting some pretty mixed data from Google. Looks like some guys run them but it's a mixed bag as to what tyre sizes fit and if fender rolling is needed. Prefer not to have to roll anything.
et39 will fit, make sure the centre bore matches e36 and not e39 (e39 have different centre bore to all others). Based on the offset they probably aren't e39 ones though.
Tyres would be 225 or 235/35/r18, Depends if you want a slight stretch.
Edited by Rubix
They will fix easy. As for tyre size it's really up to you. I think M3AN (Dave) is running 225/40/18 front and 255/35/18 rear on 18x8.5" others run 215/45/18 all round.Just depends on what look your going for and how you drive! ; )
Sent from my SM-G930F using Tapatalk
