Eddie
E46 318i wagon v8 swap
Great work.
Did you use the e46 fuel pump and fuel filter, or was it not strong enough?
On 06/02/2017 at 8:34 PM, zero said:
Great work.
I put the e38 fuel pump in the e46 holder
  • Like 2
I've just been sorting out the little things like the air filter and washer bottle
  • Like 2
The car has done just  over 1000km now and it's had a small oil leak on the left side since I first got it running, so I thought it's best I fix it
I have been tidying up the last of the wiring. Got the reversing lights and camera going again
On 15/02/2017 at 11:02 AM, Michael. said:
Btw, what's that large tank on the driver side? Oil reservoir?
Yes it's the oil tank for the engine. The tank can hold 8l but only holds around 4-4.5 l  while running as the extra oil is circulating around the engine, filter,pump and oil lines.
The only pic I took while I was making the tank
  • Like 3
