rob03814
X3 e83 6 Disc Changer Removal
Has anyone on here removed the 6 disc cd changer from the center console on an X3? Just wondering if removed it will set off any codes or cause any issues?
Thanks...
It will not cause any codes or issues. The radio will just stop showing cd Changer as a mode option.
There is a LOT of storage there without the Changer taking up near the entire console.
This isn't meant to be sarcastic, but I can't figure out any other way to say it.
Google the cd Changer Retrofit instructions for an e83 ( I found them 15 months ago) and follow them in reverse?
http://www.bimmerfest.com/forums/attachment.php?attachmentid=344999&d=1349825497
basically lift off the finisher trim, remove the console remove the stacker amd brackets, reinstall console drop the new liner into place.
