WYZEUP 281 Report post Posted June 26, 2017 Hey guys, Currently working my way through the certification process on my car and as i have changed steering racks a bumpsteer test needed to be done. Only changed to e36 rack and have spaced in the middle of the subframe and test has come back with 40mm of bumpsteer....would hate to know what some uncertified vehicles have after this change. Has anyone here got any knowledge on correcting bump steer or any solutions, i did consider raising the steering rack which also means i need to lift the motor which will cause some driveline issues? any help would be great so i can get it sorted Quote Share this post Link to post Share on other sites
Funkyflynz 150 Report post Posted June 26, 2017 Moving the rack is one option, you might find it easier with some adjustable tired ends such as these... http://131abarth.com/shop/uniball/en/home/768-raidetangonpaan-bump-steer-kitti.html https://www.akgmotorsport.com/product/bump-steer-correction-kit-e36/ http://www.bimmerworld.com/Suspension-Steering/Steering-Components/Ground-Control-Adjustable-Bump-Tie-Rods-E36.html 1 Quote Share this post Link to post Share on other sites
