35 posts in this topic
Bought my first BMW in early 2015, it was a fairly standard 320i that was converted to manual and was put on HR springs and KYB shocks with a set of replica volk wheels
19820787_1935477239811085_1935870723_o.thumb.jpg.cb281703f18bbb1bdc55e1c1529cfbc7.jpg
19830080_1935477203144422_1898740473_o.thumb.jpg.623d865072b9968d0412e4252387a8f6.jpg
Used this car as my daily for about a year and did a few things to it, had plans for it but at the time i was driving it every day and it served its purpose well
19814135_1935466683145474_1908990570_o.thumb.jpg.319fe52e063a9f0f7f32b58426f1631a.jpg
19850639_1935479766477499_1740201980_o.thumb.jpg.5e3cabde6cf2d6398b78ddaf7c34ed1d.jpg
Put some TD144s on it had a problem with the tyres on them changed them down a sidewall thickness and put a bit of stretch and they worked well
also put on a Grip Royal steering wheel on to replace the factory wheel it had
and that was about the extent of the "mods" i had done to the car until the front cross member gave out on me and broke the small tab that bolts the sway bar bracket on. So at that point i decided to it was time for a M20B25 upgrade "might as well change the engine while i'm fixing this front cross member" I said and from there things spiralled out of control and what started as a 2.5 swap has now turned into a M20B25 stroker turbo build
so the motor was pulled
19821027_1935476979811111_1532473922_o.thumb.jpg.f444da0d31c5935bcbc493cee9684731.jpg
stripped everything out of the engine bay and shaved off unnecessary brackets for a nice clean look
19814301_1935476933144449_1906549618_o.thumb.jpg.1e9cfad4643a6e28f4b99b3124c126bb.jpg
paint and rust work (leaking brake master i believe) were done at Riverlea Panel and Paint
19859324_1935472319811577_1510258689_o.thumb.jpg.d02eac754a262a54d1889d98d7fe6254.jpg
19830319_1935466703145472_1615990402_o.thumb.jpg.2b24d701729f38de84fa35218f98b656.jpg
Braided clutch, fuel and brake lines being installed (some shown)
Brand new Fenix radiator
E36 steering rack and custom shaft
wanted to go Z3 but best option at the time was e36 so went with that
During all of that i picked up a used M20B25 from Auckland
came from a 89 vert with 180000 ks on it but engine ran fine so guess it made sense to rebuild it lol
In went a 2.7 Stroker kit
2.7 crank
135mm rods
M50???? pistons can't remember what they came from now
19814505_1935475219811287_1059951610_o.thumb.jpg.6663d900972547f63223b854a4086028.jpg
engine was sent to Cambridge Engine Services for cleaning and checking
all was good so in it all went using OEM bearings, rings and gaskets down the bottom
19850703_1935472389811570_1264017805_o.thumb.jpg.50e0766e477df5fab0a97585719ecf88.jpg
Crank scraper and sump baffle were fitted (pain in the ass with two gaskets and very tight baffle to install)
Head was ported and polished by Jim at same shop
new valve guides and stainless steal valves installed
Head was planed just a smidge
Bolted together with an Elring HG (2mm) and cap screws
head fitted with brand new valve springs and retainers, a reground 272 cam, HD rockers and oversized eccentrics
brand new water pump fitted
19807727_1935466733145469_1782974946_o.thumb.jpg.da3685d29b5df74c97ecd56d18053d24.jpg
Just currently needing a timing belt and tensioner which i'll pick up this week
19807863_1935468033145339_1877256673_o.thumb.jpg.9e5646e1d6c9c1f0b73ab13b7923ed2d.jpg
couldn't resist test fitting the manifolds and turbo when it was all torqued down lol
won't be running it with the turbo straight away as it will be easier to run the motor in on the factory ECU that way i'll have the cam run in and the rings will seal really well before boost is added which will be courtesy of a Sinco manifold, front facing plenum and Master Power MPR-494
19820944_1935477523144390_1218180391_o.thumb.jpg.d2bd558a0c029399ae5b66fa95dfd133.jpg
19850525_1935466466478829_1398353598_o.thumb.jpg.42133a576462592b9aceafcf4ccd73a6.jpg
19850837_1935466449812164_2003392036_o.thumb.jpg.4dac735b2fdaa95d4212235f18543412.jpg
in the meantime tho just going to be using the standard intake and exhaust , intake fitted with custom fuel rail to run -6 fittings and braided lines which the whole car has been converted to (pics to come)
19850911_1935466583145484_2121369170_o.thumb.jpg.786240b65526377a8915219563f573f4.jpg
^ pic of the lines coming into the engine bay unsecured atm brake and clutch lines also being changed to braided lines
all bushes being changed to revshift aftermarket ones offset bushes above
yet to do the diff mount bush as I'm looking for a medium case diff at the moment and will be twin mounting it underneath the car shortly.
E36 adapter shaft with solid aluminium centre
Motor and gearbox will be going in shortly with revshift gearbox mounts and Range Rover v8 engine mounts
using a spec stage 3, 6 puk clutch and lightened factory flywheel
19820865_10211044134191617_676431403_o.thumb.jpg.e53eab6ee465391370501cde332896bb.jpg
19840235_1935466639812145_1587499755_o.thumb.jpg.f113fedea0cb47d729d0e763324fa7cb.jpg
shipped for $700 from Evan at SpeedFactor will definitely be able to handle the power I'm expecting to make
will be picking up some seat rails for these in the next few weeks and bolting them in (can't wait these seats are awesome)
will be updating this build very soon
for now peace
Edited by FritterMullins
correction
8 people like this
Nice Build! Look forward to seeing its progress
What seats are those?
Alpina recaro sport seats came on some e30s and a few other models i believe
1 person likes this
cheers mate been working on it for a little while now can't wait to drive it again
yey for another turbo m20 :rolleyes:
1 person likes this
Awesome build! Definitely following. Good stuff putting AN lines throughout. Curious to hear your thoughts on that clutch once it's in there. I've got the same one sitting here. Also, that manifold - does the oil filter need to be relocated?
Thanks man, it's probably gonna be a bit of a pain to use in traffic but I'm sure I'll get used to it. Manifold clears the filter but I'll relocate it anyway to tee in oil pressure gauge and also make it easier to change the filter come service times
1 person likes this
Got fuel pump in today using AEM 320lph in tank I've heard they're fairly new on the market but they seem capable and well priced
Install is pretty straight forward comes with strainer thing, small adapter hose, wires and all the clips needed to put it in minus the cable ties I used to hold it tight
Chucked in a new pump o ring too because old one was a tad cracked
Hooked up the main hose has a swivel on the end with a hose clamp hidden
Also got fuel lab filter hooked up, used a small bracket to bolt the filter to the where the tank bolts to the rest of the car.
Had to use a 120 degree fitting to get the hose to line up down the rest of the car so I could use the factory clips to tuck the fuel hoses up in the channels
looks a bit spaghetti under there at the moment and it may need attention when I go for cert but it's pretty sturdy for now
with the factory fuel filter panel it looks real tidy
using all the factory clip points for the fuel and brake hoses with cable ties to keep them spaced
I had Chase Bays make me up a copy of all the hoses he is using on his m54 swapped e30 cost about $900 shipped for all fuel lines and fittings up to the firewall, a fuel lab filter and rear brake lines all the way from the firewall to the Flexi lines at the rear calipers. May have been able to do it cheaper locally but don't get a lot of time off work during business hours so was easier to go with something a little more "kit set" for this
spelling mistake
1 person likes this
Isn't that steering rack adapter gonna be a prick to get the downpipe around?
I would be concerned over using cable ties to hold the fuel pump in place. Cable ties will deteriorate in a petrol environment . I would have used 2 stainless steel hose clips (Wurth variety)
1 person likes this
Had zip ties for ever never had a problem :)
I think it should be okay if not i can always take it out and chuck it in a lathe and turn some of it down
to be honest i think the fuel pump would need replacing before the cable ties do
Got some work done on the motor today in preparation for it going back in the car tomorrow, just stuff that would be easier doing whilst it's out
first was was the timing belt and tensioner
im running a gates belt and brand new tensioner, spring and pin seemed to be perfectly fine so was just re used as the tensioner doesn't actually come with them
Then was torquing up the front crank bolt, for this I made a tool to bolt to the back of the crank and jam on the floor to keep the rotating assembly from.. well.. rotating..
the tool was made from a spare flywheel plate washer and a long bit of steel welded together
pretty simple but makes it very easy
then i greased the front bolt and washer for an accurate reading and put a very big torque wrench on the front IMG_4034.thumb.JPG.75977c38773794d8eb2a6084f92b03da.JPG
easy peasy
motor goes in tomorrow so will have have lots of photos of that to come will hopefully post that tomorrow night
Adding on
2 people like this
Managed to get quite a bit done today
first went and picked up engine crane from a mate (thanks Josh), which somehow fit in the back of the my daily E30
then engine off the stand to do the flywheel clutch and gearbox
20273432_10211220364957276_737310493_o.thumb.jpg.c5819f25ca6779807ff46c515d3e90f9.jpg
I had the flywheel resurfaced at Waikato clutch and Brake and then lightened at Cambridge Engine Services, not a huge fan of ridiculously light flywheels so not a lot was taken off the flywheel rear side
20273025_10211220364237258_1831494354_o.thumb.jpg.85fab837f5e9d7828aecf44dc3c806d6.jpg
20273454_10211220363237233_1430878638_o.thumb.jpg.4b8e3e7ee794487f3dca3fcc917e5540.jpg
Brand new pilot bearing that came with the spec clutch kit punched in with a socket
20273066_10211220363157231_131772068_o.thumb.jpg.ea0c57d4d805fe9c0a8e629971240488.jpg
Spec 6 puk clutch and pressure plate were bolted up with thanks to Kerry at Mosen Euro Parts for the spare pressure plate bolts late friday afternoon , probably would of had to put off working on the car for a week or two waiting for brand new ones from germany
20314699_10211220362677219_327004661_o.thumb.jpg.8f1f661c7be895f0db7392a43648d7bb.jpg
20273640_10211220362437213_1159213692_o.thumb.jpg.419ad820c035fe9dde5520c8520329c0.jpg
then gearbox was bolted up with brand new thrust bearing included in spec clutch kit and slave cylinder from Gavin at Euro Italian along with pretty much every nut bolt gasket and o ring on the car big thanks to him
20273284_10211220362357211_1521824647_o.thumb.jpg.30db0b6a655f3ad61d10c6b6a187227b.jpg
20316836_10211220361797197_1597855547_o.thumb.jpg.1d9f774baf615dd2cf41e8461e8ca466.jpg
20273179_10211220361197182_860546522_o.thumb.jpg.2776d129f4bb313df18e2914836c1f84.jpg
20317249_10211220361717195_1804251369_o.thumb.jpg.662973209b625abef6ab07628a19d0ed.jpg
After a few swear words we got it in (not too difficult being the stock motor really)
thanks to my lovely girlfriend for her help operating the crane whilst i wrestled with the motor
heaps more updates to come now as there's plenty to be done on the car now that the motor and gearbox are in for now though time for beers
2 people like this
Have just been tinkering with a few odds and ends for now (starter in, intake manifold on, timing covers, thermostat housing and cleaning the interior carpet) and was wondering if anyone knew what the best way would be to blank off the turbo drain plug in the sump temporarily while a run in the motor n/a? I have tried googling a few things but nothing really comes up I might have to get someone to make something up
anyway here's some pics
Also needed a motor rebuild fix so am starting on my new 2.7 m20 build for my daily
so have this 2.7 bottom end to use with another 885 head am wondering if I should make another thread for that build however progress might be a little slow on it as I really need to get my turbo build running
pics of the daily
standard 320i auto (fairly) soon to be 2.7 manual
also have my 2.0l table build, I have a stripped m20b20 block which I'm converting to a coffee table for the man cave, just need to get it acid dipped and then have some glass made up for it $60 it cost me from mosen with a few extra spare parts attached to it
too many projects not enough time lol
1 person likes this
For the oil feed, could you just use a fitting with the end welded closed?
Edited by zero
1 person likes this
true, i think thats a good enough reason to invest in a tig welder lol
2 people like this
Decided it's time to get cracking with some of the light rust on the car seeing as I'm waiting for parts so don't have a too much to do on it right now, I've known about the rust for a while but have been too busy to get round to it.
the plan is to also straighten the rails(?) underneath the car where previous owners/mechanics etc have used it as a jacking point which has crumpled it in
The guard also have the same problem and some small amounts of rust developing
im most likely gonna be cleaning out and repainting/sealing  the whole inside of the guard area in the next week and also straightening, painting and sealing the rail(?) on the both sides. Then I can work on the rust cause by the leaky tail light lol :D lots of fun ahead of me
nice build
6 hours ago, crunchy said:
nice build
yo cheers mate
2.7 crank
135mm rods
for now peace
Great seats looks like Alpina stripes where'd you find them? Know what they're out of?
they're alpina sport seats, the sport seats that came in e30s were apparently the only real recaro seats they came with and were quite rare and the alpina trim even rarer. i bought them off an old guy from Auckland, he said they were out of his e21 which i think also came with the sport seats
1 person likes this
Great looking build, look forward to next update
Edited by skidz
spelling!
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
