3 hours ago, skidz said:
Great lloking build, look forward to next update
thanks bro. Been a bit busy with a few other projects but i'll be getting back into it this week getting all the rust sorted and underbody sealed, then i'll be moving onto the brakes and suspension
Still slaving away on the rusty seams and inner guard areas
also found these on my laptop from when i finally decided to break into my glovebox after about a year of owning the car.
12884374_10207064173975099_601422187_n.thumb.jpg.9602efaf02516881fe9e4df6cf1fc338.jpg
12421533_10207064175855146_1595198970_n.thumb.jpg.91147def61e574540652fa391f3f0011.jpg
typical bmws driver bluetooth set lol
  • Like 1
Haha, classic.
Among other uses, that lube is actually pretty good for getting stubborn vacuum and other hoses to slide onto what they're supposed to. :)
Always look forward to updates, keep up the good work! Particularly interested to see what you do with your exhaust..
Edited by Kepes
6 hours ago, Kepes said:
Haha, classic.
The plan for the exhaust is to just run factory one during run in and then when I make the switch to turbo I'll probably be making my own exhaust by that point which will be 3" down pipe splitting off when it hits parallel with the ground into twin 2.25/2.5" pipes with a few resonators and maybe a muffler depending on how loud it is
also good tip on the lube, I'll keep that in my toolbox haha
Put the alpina seats in tonight, had to use some  ATS Performance recaro adapters to use standard E30 rails. thought I had the right adapters but I'm pretty sure they're adapters for E21 seat rails.
Still working on rust as well lol, got a cut from another car from mosen that I'll weld in next weekend
Edited by FritterMullins
Spelling
  • Like 2
Been waiting on gearbox mounts which finally came today so got those in in about 10 minutes
started on the rust in the boot caused by leaky tail light/ boot seal (probably both) easiest way i've figured to do it is to just cut it all out and weld in place from a donor car so have all the rust cut out and now just need to cut it again on the other piece and trim till it fits perfectly which will be the mission for the weekend. Funny how the piece that i got cut needed some rust repair on it as well lol, typical rusty old bmws.
Can't wait to get all this rust finished up so i can start on other tasks, will be nice having a rust free e30 though.
21267694_2010493968976078_1621823630_o.thumb.jpg.6dd31c631c883317e62f51aa9cc741ea.jpg
21277612_2010493905642751_1577032475_o.thumb.jpg.b1d9c970f22126cdde588a9acddd5249.jpg
21277608_2010493625642779_2122062670_o.thumb.jpg.f073d8b2ba80b6ba2b4f1e5d08e400dc.jpg
21267650_2010493482309460_1914241902_o.thumb.jpg.7a038d12471f6d6835e1539c7ebf178a.jpg
Good stuff! Nice to see you're doing the rust 'repairs' properly rather than just painting over it... like i'm guilty of doing, one day I'll get round to it!
Where did you get the driveshaft loop/hoop?
thanks man, seeing as there was literally no metal to paint over as there was just a big hole i figured best to do it properly and i plan on keeping the car for a long long time so i may as well do it right the first time.
as for hoops i got them from Mike at Euro Turbo, he's great to deal with knows his stuff and has helped me out with most things for the build
https://www.euroturbo.nz
  • Like 1
Damn it’s been over a month since I’ve posted on here, progress hasn’t stalled but it has slowed down due to a few very busy months and unfortunately it looks to be only getting started with Christmas and new year coming up. Along with that I have a holiday coming up next year which dries up the spending on the car for the meantime but once that’s over I should be on a mad dash to getting this thing started and ran in. All that said the car hasn’t just been sitting around, in fact it’s about 99% rust free now. I used some rustroy to get anything not major killed off and the big chunk of the rear boot floor and bumper being hacked out and a new piece put in place
this is was a very tedious task requiring a lot of cutting, grinding, fitting and welding done to get it lined up. It’s not perfect but all I care about is it not rusting again so I’ll be putting in some heavy brush on sealer on this week and sorting out some tail light gaskets and a boot seal as well. Nice to get this daunting task out of the way, really motivates me to move onto some more interesting stuff lol
  • Like 1
odometer never worked when I bought the car so decided to pull it out and find out what gears I needed to fix the problem but then discovered all gears to be working perfectly with all teeth intact lol will try putting a new gauge in there when the cars running again to keep accurate track of how far I’ve gone on rebuild but decided to make some progress today no matter how small and painted needles red to add about 7.5hp (roughly) :D
Back at it, converted battery to run in the boot using all oem parts, getting close to starting now. Recently moved house so have been really busy setting up the new and bigger shed can’t wait to get going in 2018 again lots of work still to be done
  • Like 2
Any updates for this? Running boost yet?
  • Like 1
No updates yet unfortunately, life been getting in the way and will continue like that with summer coming up. Have swapped out to a g260 box and started on an mtech2 fibreglass kit will get back into it next year and hopefully get some good progress made.
Pulled the sunroof out today to take to be turned into a moonroof. Previous owner had permanently sealed the panel in so was expecting to find more rust but luckily they had sealed it off as a precaution.
  • Like 1
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
