Followers 0
3pedals
What did you do to your SAAB today
16 posts in this topic
Since the chassis is now a well behaved thing  -------------
Bought it a 235-R project engine - that's the one with a nitrided crank, better valves  2.3 litres and a bigger hair dryer  and a few other things. Running on the stock  DME it should do 140kW and 280 Nm - same as a stock M52b28 except  max torque is at 2,200 RPM.
With the R DME it will crank out 170kW and 370Nm  but then it might need a new gearbox every month or so?
1 person likes this
Just to clarify- this is the same SAAB you picked up because you didn't want a project? :lol:
Keep up the good work, SAABs are well off the radar and will stay that way now the brand is dead
2 people like this
The car was just a lot of remedial maintenance and some improvements - the Engine is a project though.
Saabs are at their low point and IMO the 99-02 9-5 will be a car to collect  particularly in 2.3 litre livery
 Keen to find a genuine Aero
But with a proper trans??? ;)
Eventually yes but they are Soooooooooooo rare as so it might be a manual conversion.
1 person likes this
Front wheel drive though?
Yes it is front wheel drive  hence the likelihood not to go silly with power and all of the work / learning on suspension set-ups for the Saab.
Update on progress:
Engine now 90% built replaced a lot of crusty O rings in oil supply and in the manifold  should be a lot better at oil delivery and have no boost leaks
Nitrided crank, high strength rods and pistons are a work of art compared to the stock ones.
Will fit the upgraded PCV kit and should be in the car by the end of the weekend - having the use of a hoist makes a huge difference.
All done engine in fully connected up, running and test driven- Wow what a difference - effectively a fresh 2.3 motor  oil pressure is perfect , engine quiet as with  torque delivery like a diesel and power delivery like a petrol.
Makes the newer 328  4 cylinder turbos look pathetic
Having a bit of trouble getting the power down
Front wheel drive joy.
Here is my plan "B"
Just drive it backwards.....
On 8/27/2017 at 6:40 PM, 3pedals said:
Here is my plan "B"
is that a Saab powerplant in an e30?
Snap
P.S looks like a manual conversion is possible 5&6 speed gearboxes coming up in the U.K
Found a couple of vacuum leaks which were covered in the post about booster seals, running like a watch, pulling like a train. 280Nm from 2,200 RPM through to 5,500
Genuine aero on trade me for $2,500 184kW and 370 Nm - but into my speaker project so no cars projects for a year !
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
Followers 0
