M3AN
MSS50 DME Errors - Thoughts?
4 posts in this topic
E36 3.2 M3.
Codes come back after being cleared when engine is restarted and idling.
Potentially related symptoms (only potential symptoms actually):
* Engine cuts momentarily (will shut down if this occurs at idle) - used to be only occasionally (infrequently) and at low revs, now more frequently and across rev range. Oil level light comes on when this happens but no other warning/telltale lights. Oil level indicator extinguishes after a few seconds. Actual oil level is fine.
* Smell of unburnt fuel from engine bay area, no obvious leaks.
Any ideas?
Doesn't look ideal...
Any recommendations on how to test these things or who could take a look?
Edited by M3AN
Will message you a guy who can solve, only deals with the trade now
Edited by E30 325i Rag-Top
1 person likes this
So, I got my ECU back and the experts said that what's in the picture above wasn't the problem, that just needed a bit of a clean.
But they did find a itsy, bitsy, teeny, tiny component that was busted... it was way smaller than a typical ant, no chance I would have spotted it or been able to fix it myself.
Car is in parts but am hoping to plug it in and at least turn her over on the weekend to see what happens...
1 person likes this
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
