Followers 0
3pedals
Underwhelming service
4 posts in this topic
I picked up a second hand brake booster for the Saab as it has a leaking seal and I figured it would be easier to swap the seal on a unit out of the car and then just swap the boosters over. I took the booster to a highly recommended / reputable?  service party to get their opinion of the unit and a cost to replace the seal.
Their response was - seal is toast - unit needs to be completely stripped down using specialist tools to replace the seal - estimated cost $250 plus parts of $45 or more,  can't be tested without master cylinder so no warranty on work, one week turn-around.
My solution- bought the overpriced seal  and fitted it in 10 minutes as it is an external component.
  • Special tools used - trim removal tool, piece of wood and hammer (shaped a cup in the wood to fit round the seal - 30 seconds),
  • old seal removal 30 nano seconds,
  • new seal install - 5 minutes prepping and looking at it and 3 minutes carefully installing it,
  • vacuum tested using vacuum pump and sink plug in master cylinder hole - perfect.
6 people like this
Cool story.
7 people like this
And does it work ---------- YES
1 person likes this
I guess that's part of the reason DIY is always a popular option.
1 person likes this
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
Followers 0
