pldubs
Tyre recommendations 19x9 et 20 e91
About to look into tyres for my style 95s
any suggestions, make, model, supplier ??
225/35-40
245/35-40
cheers
Bridgestone RE003's are very popular around here.
will not recommend re003's for stretching 225 onto a 9inch rim.
probably something like falken fk452/453 will do the trick
FYI our current set up on our E91:
18x8 ET13 225 40 18
18x9.5 ET25 with 255 35 18
Could have gone with 265 35 18 on the rear for a straighter sidewall.
Seeing as you are trying to fit ET20 on 9" wide rims, I would say you are bang on with 225 front and 245 rear otherwise it will need some guard work.
i had 235/35 on a 9.5 and there was quite a bit of stretch. just depends how stretched you want the tyres? a 235 on a 9 would be a nice balance between the two
Ended up getting re003s in 235/35 and 245/35.
pretty stoked with the fitment, the rear rubs with a car load of adults around roundabouts, nothing major though just a slight touch.
cheers for the input
