zero 1160 Report post Posted August 26, 2018 Can you tell us more about your supercharger plans? Is there a kit that enables your supercharger to be mounted up? Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted August 26, 2018 Hey Nathan there's no kit that i know of, i was going to use the jag xjr supercharger as there was a kit in the states that would mount it up. But couldn't seal the deal on that so went with the AMG charger. I'm just going to set it up the same way as the jag one. Get some custom intake adapter plates made from bmw to charger. Then will try and use the Bmw fuel lines and injectors, the Charger has an intercooler integrated into the bottom of the charger itself so would "hopefully" sit in the bmw valley pan area. plump it up and either chip the ecu or go aftermarket worst case. Thats the rough idea at the moment for it. check this build out, this is what got me on to the idea. https://www.r3vlimited.com/board/showthread.php?t=418571&page=6 Thanks 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted August 27, 2018 20 hours ago, e46v12 said: Hey Nathan there's no kit that i know of, i was going to use the jag xjr supercharger as there was a kit in the states that would mount it up. But couldn't seal the deal on that so went with the AMG charger. I'm just going to set it up the same way as the jag one. Get some custom intake adapter plates made from bmw to charger. Then will try and use the Bmw fuel lines and injectors, the Charger has an intercooler integrated into the bottom of the charger itself so would "hopefully" sit in the bmw valley pan area. plump it up and either chip the ecu or go aftermarket worst case. Thats the rough idea at the moment for it. check this build out, this is what got me on to the idea. https://www.r3vlimited.com/board/showthread.php?t=418571&page=6 Thanks Ah this is great. I was thinking about doing something similar with the ute, but i haven't managed to track down a charger yet. Where did you get yours? Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted August 27, 2018 Hi Francois I purchased mine off euro1 auto spares. But had a jag one lined up, it was from trade me. But couldn't come to an agreement with the seller If you keep a look out for any jag xjr model that is getting wrecked, it should have the charger like the one above. Thanks Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted August 28, 2018 7 hours ago, e46v12 said: Hi Francois I purchased mine off euro1 auto spares. But had a jag one lined up, it was from trade me. But couldn't come to an agreement with the seller If you keep a look out for any jag xjr model that is getting wrecked, it should have the charger like the one above. Thanks Thanks mate, just bought one from them haha 2 Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted September 9, 2018 Hi Team another small update so spent the weekend pulling apart the m60 motor of it's heads and timing system. Giving them a good scrub Assembling onto the m62 block as you will see i rtv silicone everything as i don't want any oil drips coming out. new oil filter. new knock sensors So went to try and put the PMC adapter plate on the box but realized its made for left hand drive for the starter motor. so angled grind the right side to match the left hopefully its fit. Thanks Richard 2 Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted September 22, 2018 Hi Team another small update so have spent the last week just modifying the adapter plate to fit. I had to grind out the holes that bolt to the motor, grind a bit of the box to allow the bolts and starter motor to fit. But know she fits perfectly. few pictures of the flywheel clutch and adapter plate. almost there. Thanks Richard 2 Quote Share this post Link to post Share on other sites
B.M.W Ltd 950 Report post Posted September 22, 2018 Did you dial in the adapter plate on the engine after making the adapter plate modifications ? Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted September 23, 2018 Hey Glenn Wasn't sure what you meant so i googled It No i didn't dial it in. However the holes that i did make didn't effect the position of the adapter plates itself when bolted to the box or motor. So hopefully the company that made it dialed in. Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted September 23, 2018 (edited) So just another small update, doesn't look much but spent a few hours on my back putting it in. Now i can officially say it has three pedals Best part was i didn't have to take the steering colum off which i read online that i was going to have to do. master cylinder and clutch lines all put in and ready to go. Edited September 23, 2018 by e46v12 4 Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted October 14, 2018 (edited) Another update Team This was a couple of weekends work, Can almost see the finish line. So motor is now mounted, had a couple little hiccups as you do. Had to remove the gearbox to get the motor in, had a few rear axle bolts give us grief so smashed them off and had to be replaced. New belts put on and asc+t throttle plate removed, new sway bar stabilizer arms and rebuilt Diff from Kayne Barrie with 3.15 LSD So tried the factory 525i diff but was slightly too long, will need to get it shorten by 27mm. Left to do. Reattach the rest of the front end. Secure electric fan onto Radiator Sort wiring out, reverse lights, car to read in neutral and jump starter motor relay. Refit exhaust And thats about it. Can't wait! Edited October 14, 2018 by e46v12 8 Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted November 4, 2018 (edited) Evening Team So the day has come finally and we have got the M60b44 with 5 speed swap up and running. Long time coming but was worth it. shifts really smoothly, sounds great alot quicker that the auto box. Took her for a few test runs, gave all the helpers a go at drive her too. So just small things to sort out now. tidy up electric fan wiring, get a bracket for the clutch fluid reservoir, Gear knob, put bonnet back on and get a final tune. One question for you guys if you can help out in any way. 5th gear keeps popping out, it won't even stay in position at all. any ideas of what could be the problem? Thanks Richard Edited November 4, 2018 by e46v12 2 Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted November 4, 2018 (edited) here is a vid, again all filmed on private roads Edited November 4, 2018 by e46v12 2 Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted December 23, 2018 (edited) Hi Team So finally have the 540i sedan all done wof and rego'ed. All new shift linkage bushing kit, changed the exhaust to v bands for easy of removal, radiator fan switch for the electric fan and swap the wheels to the powder coated white style 135. Through a long process of elimination found out that the issue with fifth gear popping out was one missing dowel pin between the gearbox and adapter plate. Also got some adjustables for it, handles really well now. Now all that is left is to book in a tune with Gavin at Hi Velocity. This will be my new daily driver and i can now get back to my other e46 project another project to cross off the list. Edited December 23, 2018 by e46v12 2 Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted December 24, 2018 Great work Richard! When are you planning on coming to Auckland for the tune? Perhaps we could arrange a meetup if my car is running again by then... currently installing XYZ coilovers too and a few other teething issues Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted December 24, 2018 (edited) Hi Ian would definitely been keen for a meet up. I haven't booked a time yet but Gavin has told me to touch base after the 10th of Jan. Question Ian with flywheel and clutch setup do you have much flywheel/gearbox chatter? Also how was your m60b44 motor like when you 1st had it running? mine is idling lumpy which im hoping a tune will fix. Thanks Edited December 24, 2018 by e46v12 Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted December 24, 2018 Cool, Gavin's a good dude and super helpful! I was running a JB Racing Flywheel and stock sachs pressure and unsprung friction plate which was fine. Upon going to supercharger figured it was best to uprate and I regret listening to the guy at Autoclutch when they were still around. He modified my 265mm JBR FW to fit an e36 friction plate (240mm I think?) with custom spline and associated release bearing, drilling new dowels into the FW and now everything is custom, uprating the spring force on the pressure plate. The release bearing he gave me didn't fit onto the shaft of the gearbox and his comment when I questioned him was "it's all custom, what do you expect. Use a flapper wheel to grind out the centre and make it fit". I was not impressed after spending a lot of coin. Setup is OK, but slips a bit when giving it sh*t 2nd to 3rd... which likely means an entirely new setup = $$$. They shut down about 1-2years ago... I did run cams in mine too, so was a tad lumpy, but nothing I would expect otherwise? Motor was running sweet after the rebuild on the standard M60B40 DME. I did replace all vacuum hoses and modified the PCV setup at the time. Best to check for vacuum leaks and the MAF before taking it to Gavin. Quote Share this post Link to post Share on other sites
zero 1160 Report post Posted December 25, 2018 @Creaver @e46v12 Bit cheeky, but if theres space for one more, I'd love to see the setup on both your cars, as it will help me as I'm part way through my e46 m62 build. Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted December 26, 2018 Hey Ian that sucks to hear about the clutch setup. Hopefully you have a better set up that can handle your 600hp. The car runs fine on the M60b40 Dme, I put it down to the gearbox and flywheel being a lot lighter which may have put the balance out a bit, so the motor rocks just a little more now making it seem the motor is lumpy. Which is probably creating the excess chatter noise. Nathan definitely keen to come to check out your project too. The more the merrier i say, lets tee up a day and time. Quote Share this post Link to post Share on other sites
zero 1160 Report post Posted December 27, 2018 9 hours ago, e46v12 said: Hey Ian that sucks to hear about the clutch setup. Hopefully you have a better set up that can handle your 600hp. The car runs fine on the M60b40 Dme, I put it down to the gearbox and flywheel being a lot lighter which may have put the balance out a bit, so the motor rocks just a little more now making it seem the motor is lumpy. Which is probably creating the excess chatter noise. Nathan definitely keen to come to check out your project too. The more the merrier i say, lets tee up a day and time. Sounds great. Always happy for you to see my project, and would love to see yours. Gavin is an absolute genius, so it will be interesting to see what improvements he gets. 1 Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted February 24, 2019 (edited) Hey hey everyone long time no post, so alot has happened since last year. Long story short i made a big F@#K up with the manual swap. So the PMC kit does work with the zf 310 box i have, so does the flywheel but the clutch side is where i went wrong. The clutch kit that came with it is made for the zf 39dz box (which i also do have) which states on the PMC website also. The difference is the input shaft and sleeve are bigger on this box same as the 420g boxes, compared to the zf 310 one. Zf 310 input shaft Zf 39dz box So a few months back notices a release bearing was making a noise, thought that isnt right but kept running the with it. Wasnt till two weekends ago it completely shat itself. Was driving to auckland and all the sudden it wouldn't let me select any gears luckily i was stopping in Waiouru visiting a mate, he lent me his Suzuki swift for the remainder of the trip. Towed the car back home and took the box off to find this. Release bearing was completely wrecked. Further investigating i found the pressure plate is also not releasing at all which explains the no gear selecting but at least Friction plate is still mint like new. the left one is the correct release bearing the right is the broken wrong size one. as you can see the input shaft holes a different. The right is the M30 clutch that i got and will be using. Also I think the slave cylinder rod might have been slightly too long as you can just make out where the release bearing was grinding on the little prongs. The fingers and diaphragm may have been over extended causing the pressure plate to fail. So yeah lesson learnt there. Big plans ahead for all my projects though. I have brought a factory zf 310 box with v8 bellhousing from ebay ( currently at customs) this will be replacing the one in the e34 sedan. I also brought a lighten chrome molly flywheel from RHD engineering. Brought a 2nd hand M30b35 clutch kit that's needed to fit onto the RHD flywheel. This will hopefully get the car running mint and i will be able pop up to see Gavin in early April for a tune. Hope to meet up with you Ian and Nathan keen to check out your rides Also along with the zf 310 v8 box, i scored myself a 420g 6 speed box and associated bits. After some time to think i really want to keep the E34 540i touring factory as possible as i dont want to butcher such a nice clean example. So all i will be changing on it is converting it to a manual, so no more supercharger for that car. But here comes the fun part, You all may remember a build thread from Eddie, his e46 v8 wagon? well i will soon be the proud owner of it. I have test driven it and man has he done one of an amazing job on making it look and drive factory with the M60b30 v8. My plans are to drop my spare M60b40 into it. Convert it to manual with the PMC adapter kit and Zf 39dz box, and lastly super charge it with the one i was going to use for the touring, fun times ahead. Thanks Eddie for doing the hard part of mounting the thing in and sorting the oil pump issue. Also picked up a few things while up in Auckland. A whole 330i rear end going into the new e46 wagon These rare 10 inch rear ac schnitzer wheels which will go on one of the e34 cars. fronts 8.5 Also in the time passed i managed to get the Hamann's centers finally machined to fit the 3piece barrels. Just need to redrill the bolt holes and get it powder coated. Looking forward to bring you guys more updates. Thanks Richard Edited February 24, 2019 by e46v12 3 Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted February 26, 2019 Evening All Got this piece of the puzzle today, one step closer Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted February 27, 2019 Arrived today little sneak peak, will jump into this weekend. Hopefully will have the sedan back up and running. Quote Share this post Link to post Share on other sites
zero 1160 Report post Posted February 27, 2019 Such good progress! Is the e46 you are buying the one with the dry sump? Converting it to m60b40 and manual seems a no brainer. Quote Share this post Link to post Share on other sites
e46v12 469 Report post Posted February 27, 2019 Hey Nathan Yes its a dry sump setup, i think the manual swap is the easy part, eddie did all the hard work of mounting the thing in and getting it running mint. You should have a look at these guys Nathan https://adamat.com.pl/ i was enquiring about their kit till i found eddies car. Quote Share this post Link to post Share on other sites
