LsBeema
LS2 6.0ltr into E39
Hi fellow Beemer addicts. The dream is finally coming true and I'd like to share this beautiful😂😂 journey with SOME of you. ....
Should be delivered here at the workshop by Thursday from Aus.
Edited by e39525iM
  • Like 12
  • Haha 1
Not my preferred choice of engine, but it should make a great project.
What rear end are you planning on running?
  • Like 1
36 minutes ago, qube said:
I read this brru....and most of the other builds. 4-5 months research.... I am now on maybe Porsche brakes thats going to happen in +-18 months...
Planning to import an e39 M5 diff from home country S.A...but that 3.15 ratio...🤔. I would like a higher ratio end as the T56 gearbox ratios are quite low. 1st 2.66, 2nd 1.78....I heard they do like 80-90km/h in 1st. If I can remember...e39 m5 box is like +-1st4.07; 2nd 2.76...around there...
I have an open 4.1 from my auto running at the moment. A crowd in Wellington can do the lsd internals for around 2k.
I knew that I would upset a few Bmw/Euro Purists by doing a conversion like this.  We all have our reasons, and each one of us our opinions.
Alls well.
Schweet brru. 😉
  • Like 2
Looks like fun! An E39 is not such a special car that this should offend many people - E30s get 1UZs and all sorts of other engines, and Mercedes get BMW engines (and vice versa).
The old SBC was put in pretty much everything - I had one in an E28.
Look forward to seeing how you get on.
Try talking to Kayne Barrie Motorsport.
  • Thanks 1
We are importing 2 V8 engines and trans. The other for a Holden V6 VE ute. A few parts weren't clean enough for MPI inspection at customs. $250 for water blasting and +-50 extra for re-inspection.
Finally.....🤗🤗🤗🤗🤗
  • Like 4
  • Like 2
General Motors placement of reverse...🤣🤣
Got me thinking about our 333i's in South Africa. That dogleg box was Hardfreakincore. Our own M3.
Edited by e39525iM
Great engine choice, cant wait to see it up and running.
  • Like 1
23 hours ago, Michael. said:
Coolness!
What is the engine from, year / model ?
Ohh so it's an L98.
Basically just an alternative spec LS2.
Both have good output and potential.
Ohh so it's an L98.
Lets get everyone up to spec ...
http://www.themotorhood.com/themotorhood/2014/11/26/ls-engine-guide
  • Like 1
The L98 has far more potential than the LS2, the rectangle port heads flow very well and if you replace the cam before you install then 400 plus HP is easy, potential is there for close to 500.
LS conversions though thrashed to hell overseas are not that common here, I was thinking along the same lines but wasn't ready to pull the trigger. i'm really looking forward to following this build thread!!
  • Like 1
Who cares which engine.
Subscribed.
  • Like 1
Subscribed.
Then why even comment or subscribe?
Yea brru. Thats why the choice was a 98. I plan to run her stock for about a year. After getting the diff ratio sorted amd maybe hopefully brakes upgraded....then a cam, lifters,rods(pre historic...I know) ls3 throttle bod, induction, headers and exhaust and these things run hard +-500hp. Maybe port and polish heads ....yea definitely.
  • Like 1
