Bruce 1234
E39 Diagnostic help please
Hello.
I have a 1999 540i which will not crank / turn over.
My Foxwell scanner tells me the starter is disabled because of a P/N (which I assume to be Park / Neutral) block.
I have a recurring fault code: IKE, no CAN identification. (IKE = instrument cluster).
On the dash: the temperature gauge goes all the way to max, the PRND (park, reverse, neutral, drive) lights are all lit.
Help!
I used to work as a mechanic and bought this, my first BMW, about a month ago. It was not cranking when I bought it - apparently the headlights had been left on and the battery drained. Can't be that hard to fix thought I. Ha! I have fitted a new 900CCA battery and charged it fully.
Any help greatly appreciated.
Bruce.
Edited by Bruce 1234
