dirtydoogle
E53 16:9 Retro-fit?
Have myself a standard 16:9 nav unit now, but upon pulling the "chinavin" Chinese pile of junk out of the dash I have found my car was originally fitted with the basic system and has different plugs,
Now the question,
Can I simply cut the original plug off mine and wire in the new unit? I am aware nav won't work but I want the OBC functions
Edited by dirtydoogle
Nup you can't sorry.
You will need a total monitor retrofit which will require rear mount radio tuner, antenna amplifier + video module or nav unit (for screen graphics) & the harness assy. The 16:9 monitor is just a dumby (apart from the tape deck) - all the modules are remote to it in the rear of the vehicle.
Also - is the 16:9 monitor a specific X5 unit? Many are sold as fitting E38/39 & 53. The X5 unit is different as the screen pixels are set for the different viewing angle in the X5
So, either a lot of work & cost to retrofit the 16:9 or  - go back to original radio (will plug into existing plug) or another Chinavin unit.
  • Like 1
Thanks Hotwire, I'll avoid that hassle altogether.
I see some reasonable reviews on newer Chinavin units running android OS that are well priced.
So at least I would have google maps and porn
Off to eBay then!
