rxsumo
FS M30 3.5 Engine from manual E23 735i - WN - SOLD
As part of the garage clear out - this engine needs to go.
It was brought in a early build LHD E23 735i - which was a factory manual car.
Engine has done around 120K kms - but has been sitting for over 10 years.
Original E23 front cover/dissy has been removed and replaced with a "normal" dizzy front cover  - as this was originally going into a E3 project I was starting to do when the M535i came along.
Has the oil cooler oil filter housing - and the oil cooler may still be around here somewhere
Still has the original flywheel fitted.
If somebody wants to give me $200 for it, and collect it - I'd be happy with that.  (the flywheel is probably worth that alone)
Probably pay to be quick as if there is no interest - its heading to the scrap man in a couple of weeks.
cheers
Darryl
Edited by rxsumo
Hey I'm keen, but based in Hamilton. Perhaps we could arrange something? I'd also be interested in saving the other m30 and e34 stuff.
@eliongater could this be the power plant your e28 has been longing for?!
@Olaf I’ve been considering it. It would be my 3rd m30. This one is likely to be he easiest to get installed though
