Gaz
Project: The Unfamily Wagon
Couple years have gone by, didn't realize it was 3! Not a huge amount has changed but kids will do that. Been through a couple different sets of wheels, style 5s, acs type 1 monoblocks.
Picked up a dream set of ACS type 1 racing which I'll get widened to 17x9. Currently rocking some stye 24s however
600936839_Screenshot_20210521-204202_TradeMe.thumb.jpg.5f94296e7b98f72cfa24c48a2487a169.jpg
Ditched the msport kit and going more with an ASC theme. Picked up some type 1 mirrors, and painted them LSB as a tester as thinking about painting the whole car..
Had a slow coolant leak which was getting worse. Top hose looked average so replaced that..nope still leaking..so I guess nows a good time to upgrade the radiator. Was holding out for a s54 z3m one but all out of stock. Ended up grabbing a cheap used mishimoto one with new hoses. I had the radiator with the expansion tank built in so thought now would be a good time to upgrade to the m3 self bleeding system. 20220417_213551.thumb.jpg.13d0562a92b8d6c62b4e75f68023351d.jpg
Out with the old..
This was much harder than I thought. First, radiator didn't fit as the mounts are too narrow, grabbed some from a wrecker. Mine also has two wiring connectors up by the fuse box so tucked them underneath the expansion tank bracket for now. 20220417_213216.thumb.jpg.99c517b0202fa17d61bedeedc185b72a.jpg
then I had run this hose which connected to old expansion tank, to the new one. I cut it in half and grabbed a joiner from the legends at A1.
Sorted. Ran up everything and checked for leaks..
Pulled it out of the garage as to not gas out the Mrs in the office.. and it'd leaking fuel. At least it's good weather to daily the convertible
Edited by Gaz
  • Like 5
Poked my head under last night and this looks like the culprit. Loose hose clamp. Tried tightening it but made it worse.. then it got too cold and I gave up. Will give it a good clean and replace tonight and see how it goes. 20220510_224522.thumb.jpg.c78221df4c2d652733084fdde2490ff2.jpg
Much warmer in the garage today, managed to get the old clamp off and put a new one on.. fuel leaked sorted.
Looks like it might still be leaking coolant, possibly from the thermostat housing (the one thing I over looked) I see there's a bunch of aluminum housing on the market. Anyone used one with success or just stick with a factory one.
My aluminium one has lasted well. However I've struggled with making gaskets for it, but that's more likely a me thing.
