smokenbaby
Hood Lining removal
I need to remove the hood lining to fix small rust spots behind the sunroof. These are only minor but need to be drilled and welded and the underside of the roof panel needs to be rust killed and primed.
How do you remove the hood lining in one piece. I have had a look months ago but can't seem to get the front section (where the warning lights are) to come away from their clips without trying to break the backer.
Any advice would be great. Someone out there must have done this that can help.
PM me as I am hopeless at tracking posts.
