JiB 0 Report post Posted January 20, 2010 I was doing a bit of research/procrastination with aero, and came across the first decent pics of the Evo front splitter that I've seen, so I thought I'd share. It's interesting that the bottom has what I can only assume is a venturi device. I wonder what (if anything) goes behind it? Road car DTM version Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted January 20, 2010 Is it possible that there was ducting from the back of the oil cooler out down through there? Quote Share this post Link to post Share on other sites
JiB 0 Report post Posted January 20, 2010 Is it possible that there was ducting from the back of the oil cooler out down through there? I can't quite see with the road car one (it doesn't appear to taper), but on the DTM's, bump could even be there solely to dump waste air nicely...where the vent is where I'd say the low pressure zone is. And the bump's shape is a half drop shape/lowest drag shape for that cross section. But because the bump is angled, it chould also be pushing air around and away from the underside of the car (reducing underbody pressure)? All speculation of course. Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted January 20, 2010 JiB, have you had a read of Jake's DTM symposium on s14.net? Quote Share this post Link to post Share on other sites
JiB 0 Report post Posted January 20, 2010 JiB, have you had a read of Jake's DTM symposium on s14.net? No, I haven't? Would love to though? Do you have a link? Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted January 21, 2010 Can't find the whole article, but here are some individual snippets: exhaust: http://www.s14.net/jakesdtmtours/exhaust/exhaust.html driveline: http://www.s14.net/jakesdtmtours/driveline/driveline.html suspension: http://www.s14.net/jakesdtmtours/suspension.html cockpit: http://www.s14.net/jakesdtmtours/cockpit/cockpit.html engine bay: http://www.s14.net/jakesdtmtours/enginebay/enginebay.html Quote Share this post Link to post Share on other sites
