Mark Babb 1 Report post Posted April 1, 2007 Started discusing this subject elsewhere, however i still need a little help in clarifying a couple of points. I need to source a manual 240 Gertrag for a FL 320. Cannot use the 260 box due to incorrect ratios.(race series) I assumed a 240 box was the same whether it was fitted to a 318/320 or Pre FL or FL, however it has been indicated that this may not necessarily be correct. Therefore what should i look for or how can i tell which 240 box will fit a FL 320? I am aware that some of the earlier boxes had holes for the sensor however i believe this is irrelevant as the sensor on my car is on the engine ? Any advise is really appreciated as manual boxes seem to be $500 plus these days and i do not wish to waste money in getting the wrong type. Thanks Mark Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 1, 2007 According to the bible you need a 240 BMS, MB, or BMT. The gearbox number is stamped into the casing at the front edge of the bellhousing. The number is just a serial number, it is the letters on the end in which you are interested. These 3 sets of letters, either BMS, MB, or BMT, indicate it is from a 320i. Hope this helps. Quote Share this post Link to post Share on other sites
Mark Babb 1 Report post Posted April 2, 2007 According to the bible you need a 240 BMS, MB, or BMT. The gearbox number is stamped into the casing at the front edge of the bellhousing. The number is just a serial number, it is the letters on the end in which you are interested. These 3 sets of letters, either BMS, MB, or BMT, indicate it is from a 320i. Hope this helps.Thank you Dave for taking the time to look this up, really appreciatedMark Quote Share this post Link to post Share on other sites
