Neurotic
e30 318 issues
e30 318 issues
Was just wondering if anyone had any idea what is wrong with my car? I have an 1987 318 (m10 motor) which has problems. You jump in it and start it and it just splutters and conks out so you have to keep reving it until it warms up, once it warms up its fine. Changing the idle does not do anything. It has had the spark plugs, leads, and rota changed, the timing done also.
Am puzzled as to what it could be, any advice would be appreciated, Thanks.
Hey Will, do you mean the alloy bit on tiop of the Cam cover that has some vaccum lines and one set of cables going to it??
Will get pics if i can find them.
Below are two variations of the valve setup, there is a third but I don't have an example of it.
Posted Image
Posted Image
Posted Image
Posted Image
If its not what Will has put here, try the fuel pump ... my E30 few years back had the same problem and ended up it was the fuel pump
