MarcoP
BMW 328i SE 1999
As you may have guessed by the unknown nick, i'm new here and have just purchased a BMW. So far have had it for 4 weeks with no problems - but I thought i'd ask if there are any known problems with the 1999 328i?? The specs are as below
Year 1999
Make BMW
Model 328i E46
Engine Location Front
Drive Type Rear Wheel
Weight 3250 lbs | 1474.2 kg
Performance
0-60 mph 6.9 seconds.
Engine
Engine Configuration I
Cylinders 6
Aspiration/Induction Normal
Displacement 2.80 L | 170.9 cu in. | 2801.1 cc.
Valves 24 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 190.00 BHP (139.8 KW) @ 5500.00 RPM
Torque 206.00 Ft-Lbs (279.3 NM) @ 3500.00 RPM
HP to Weight Ratio 17.1 LB / HP (Vehicles with similar ratio)
HP / Liter 67.9 BHP / Liter
Bore 3.31 in | 84.1 mm.
Stroke 3.31 in | 84.1 mm.
Compression Ratio 10.2:1
Vehicles with similar horsepower and weight
Transmission Information
Gears 5
Transmission Tiptronic
Dimensions
Cargo Volume 10.70 cu. ft.
Seating Capacity 4
Exterior
Length 176.001 in | 4470.4 mm.
Width 68.501 in | 1739.9 mm.
Height 55.701 in | 1414.8 mm.
Wheelbase 107.301 in | 2725.4 mm.
Vehicles with similar dimensions
Edited by Marco
The only real problems I can think of are that you have an 8 year old car. From this age, whether you drive a BMW or a Skoda, mechanical bits do wear out. Although I've found that some BMW parts are cheaper than some Ford parts, in general, it'll cost you extra money that you weren't expecting. Anyone who owns an 8+ year old car has to get their head around that.
As others here have said - if it's got tits or wheels, its gonna cost ya!! :)
