antony 0 Report post Posted April 18, 2007 hey. when i get around to getting spacers, i'd like longer bolts. where can i get longer wheel(stud) bolts from? does the e36 have them?, and are they longer/same thread as the e30 ones? cheers antony. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted April 18, 2007 (edited) Also could be interested in this for my spacers. Im using loctite at the mo' Edited April 18, 2007 by ED1RTY Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted April 18, 2007 A good wheel shop should be able to supply you with the correct ones. Would be keen to know if the e36's are cross compatible. Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted April 18, 2007 I'd get longer studs instead, so much less hassel than having to line up hub, spacers, and wheel. Several places in the states sell them, or find suitable studs from another car and adapt those. Quote Share this post Link to post Share on other sites
antony 0 Report post Posted April 18, 2007 do you mean the studs that bolt into your hub, therefore giving me studs? Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted April 18, 2007 i know magwarehouse carries longers bolts, werent cheap thou(eyes popped when they mentioned the price!!), try a fastners warehouse theres a good 1 on rosebank road, name eludes me - but would be the best place to start Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted April 19, 2007 if you do want longer studs make sure you get them with a 60 degree straight taper. (un)Fortunately we do not stock or sell studs longer then 30mm as you can run into all sorts of legal issues when running spacers. ie the shop that sold the studs can be held liable if you have a crash and it is found that the studs came loose etc. strictly speaking spacers do not pass a WOF unless they are of a bolt on variety and do not exceed 25mm in thickness and your car has a low volume cert (opens up a can or worms here ) Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted April 19, 2007 hey i paid $2.50 from mag and turbo for some awful looking chrome ones but they are longer, its ok because i have center caps to hide the peeling chrome!! Quote Share this post Link to post Share on other sites
