boydusM325i
Honda Euro-R 2000 V-Tech $12,990!!
2000 Honda Torneo Euro-R 2200cc Type-R, V-Tech
Bellow wholesale price! Must sell...
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4680 x 1720 x 1405
Interior dimensions (LxWxH), mm 1935 x 1415 x 1190
Wheel base, mm 2665
Treads (F/R), mm 1485 / 1485
Ground clearance, mm 140
Curb vehicle weight, kg 1330
Seating capacity, persons 5
Doors number 4
Fuel tank capacity, l 60
ENGINE
Displacement, cc 2156
Engine model H22A
Max.power (Net), kw(PS)/rpm 220 ps (161.81 kw) / 7200 rpm
Max.torque(Net), N*m(kg*m)/rpm 22.5 kg*m (220.65 N*m) / 6700 rpm
Compression ratio 11
Bore, mm 87
Stroke, mm 90.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.6
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Tires size, front 205/50R16 87V
Tires size rear 205/50R16 87v
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front Double wishbone type
Suspension system, rear 5 links double wishbone type
The car is equipped with jamex springs, a custom cold air box, After market exhaust, new LSD grearbox, clutch, brakes, new bridgestones, 5 Star insurance approved AVS Alarm System.
Its been very well maintained with regular services and only been run with synthetic oils. Its a very nice tight car to drive with plenty of performance from its 220HP Type-R engine.
Large capacity boot & luxury Recaro interior add the finishing touches to a classy executive sedan.
At present the market suggests a retail price of between $15,000-$16,990
Im only asking $12,990!!! You do the math! Its a lot of car for the money...
Contact: Boyd Whittaker 021 752-616
I did read it all, but didn't see how many km?
Not that I'm gonna buy it - just the hawt version of the H22A engine caught my eye (my daily driver's an early 90s EG Civic with that motor :D).
