323e30 0 Report post Posted May 11, 2007 wrecking 323i e30 1983 coupe,..... have most parts including engine and cpu no lsd no gearbox. just ask if you need anything..... Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted May 12, 2007 Pics of car plwease~ Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 12, 2007 no crash damage just rust,,,,,, standard un kitted 323i e30 2 door.. not worth fixing so thats why im wrecking.. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted May 12, 2007 How much for bonnet and front windscreen? Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 13, 2007 bonnet may be rusty but will check, (white) front windscreen 100$ pick up from greenlane auckland.. bonnet 30$ if not rust damaged.. email [email protected] Quote Share this post Link to post Share on other sites
Guest Denny Crane Report post Posted May 13, 2007 Bootlid un rusty? Are they sport seats? If so i'll take the rear sear and the pass seat Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 13, 2007 ill check the boot tommorow and get back to you asap but think its fine. seats are fairly worn. Quote Share this post Link to post Share on other sites
Guest Denny Crane Report post Posted May 13, 2007 Thats okay i'm mainly after the frame if they're sports. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 13, 2007 i had a pair of the seats with the leg rests and arches a wile back that were worn, ill check the gararge while im there to see if there still around. Quote Share this post Link to post Share on other sites
dc2r 0 Report post Posted May 14, 2007 how many kms has the speedo done? and is it in km or mph.. Quote Share this post Link to post Share on other sites
mops 4 Report post Posted May 14, 2007 how many kms has the speedo done? and is it in km or mph.. i'm after front and rear chrome bumpers if they are not rusted or dinged. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 14, 2007 just looked over car.... body no good, panels rusted, good for windows suspension parts, diff . set 0f 3 m sport 15" rims mirrors. 323i head jetronic Msport 1983 180kms 323i complete engine jetronic 1983 202kms 323i cpu jetronic 323i M cpu jetronic full set of windows, front back plus sides to suit 2 door. ignition coil shocks, standard springs steering arms speedo reads 202kms but can easily be changed to anything only a standard 220km speedo 318i airflow meter 323i airflow meter set of e30 four door, door interior cards. 325i auto drive shaft plus other parts... Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 14, 2007 323i 83 Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 14, 2007 engine Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted May 14, 2007 Surface rust, or does it need welding up?? [bonnet] You are only around corner from me, I may pop up and look? 0211733387 Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 14, 2007 bonnet is just suface rust wont need welding, bonnet is in takanini but i can pick up tonite and take to my place in elerslie if you want to look tommorow sumtime? Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted May 14, 2007 bonnet is just suface rust wont need welding, bonnet is in takanini but i can pick up tonite and take to my place in elerslie if you want to look tommorow sumtime? for $30, yes please. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 14, 2007 sweetas, ill give you a tex tommorow and let you when you can come past to see. Quote Share this post Link to post Share on other sites
dc2r 0 Report post Posted May 14, 2007 just looked over car.... body no good, panels rusted, good for windows suspension parts, diff . set 0f 3 m sport 15" rims mirrors. 323i head jetronic Msport 1983 180kms 323i complete engine jetronic 1983 202kms 323i cpu jetronic 323i M cpu jetronic full set of windows, front back plus sides to suit 2 door. ignition coil shocks, standard springs steering arms speedo reads 202kms but can easily be changed to anything only a standard 220km speedo 318i airflow meter 323i airflow meter set of e30 four door, door interior cards. 325i auto drive shaft plus other parts... I could be keen on the speedo, gotta pic? and will this plug up to my '88 320i? how would i go about winding kms back to match mine? Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 14, 2007 yeah i have a speedo, should be the same, i can wind back kms to match yours, make me an offer... [email protected] i have two sets of speedo clusters avalible Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted May 15, 2007 Hi, How much for the 323i M cpu jetronic? assume it's L-Jet? cheers Matt Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 15, 2007 yeap its the L jetronic.. bosch0280001301 from an 83 msport coupe that had the better cam shaft and race style seats factory standard.. 80$ also have 323 intake manifold door handel surrounds central lock motors cruise control ecu Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 15, 2007 standard e30 front lip 40$ rear tail lights (pair) 60$ glove box that works!! 40$ center console 25$ (front part not handbrake part) m sport steering wheel 15$ (no leather on it) otherwise ok condition [email protected] .......................................... Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 15, 2007 e30 front lip.... 318i prefacelift e30 speedo. from 323i front prefacelift indicators 318i Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 15, 2007 Just remembered also have a good Pair of e30 325i Fog lights And also have 1 good spare fog light glass lens. for driver side. Quote Share this post Link to post Share on other sites
