Guest bridgeport Report post Posted May 2, 2004 (edited) PIONEER 50X4 SUPER TUNER CD PLAYER WITH RCA'S $200 Bridgeable Amplifier with Dual MOSFET Power Supplies 300 Watts RMS 4-Channel Amplifier POWER OUTPUT Number of Channels 4 Peak Power Per Channel @ 4 ohm 150 RMS Power Per Channel @ 4ohm 75 Peak Power Per Channel @ 2 ohm 200 RMS Power Per Channel @ 2ohm 100 Peak Power Bridged @ 4 ohm 400 x 2 RMS Power Bridged @ 4 ohm 200 x 2 FEATURES MOSFET Power Supplies Bi-polar Output Transistors 2 ohm Stable (Stereo Operation) Tri-Mode Operation Bridgeable Operation Variable High Pass Crossover (40-240Hz) Variable Low Pass Crossover (40-240Hz) 12dB/Octave Crossover Slope 6dB Fixed Bass Boost @ 45Hz High Level Inputs Input Level Control(s) Input mode switch Pass Through RCA Outputs Extruded Aluminum Heatsink Top Mounted Controls Thermal/Short Circuit Protection Power LED Indicator Protect LED Indicator Illuminated JENSEN Logo $200 PIONEER 6X9'S PROFESIONALY BOXED $100 12" UNKNOWEN SUB BOXED $150 OR $450 THE LOT DONT COME ON HERE MUCH SO EMAIL [email protected] OR PHONE 0211741365 no txt's cause i wont txt back call if your keen Edited May 3, 2004 by bridgeport Quote Share this post Link to post Share on other sites
