dc2r 0 Report post Posted May 27, 2007 (edited) As above, have a set of 4 26mm Spacers in 4x100 stud pattern, in very good condition, minimal use, came off a e30. good if your after the mad rwd offset stz or allowing wider range of wheels to be fitted,. can be used on other 4x100 stud patterene'd cars. $220 Edited May 27, 2007 by dc2r Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 28, 2007 have they ever caused any slight vibrations? the last set of e30 spacers i had did. Quote Share this post Link to post Share on other sites
dc2r 0 Report post Posted June 4, 2007 no no vibration what so ever.. up Quote Share this post Link to post Share on other sites
dc2r 0 Report post Posted June 6, 2007 As above, have a set of 4 26mm Spacers in 4x100 stud pattern, in very good condition, minimal use, came off a e30. good if your after the mad rwd offset stz or allowing wider range of wheels to be fitted,. can be used on other 4x100 stud patterene'd cars. $220 Give me a resonable offer and i may just take it Quote Share this post Link to post Share on other sites
Jonty m50e30 0 Report post Posted June 7, 2007 Gidday are these hub centric to 51mm? Quote Share this post Link to post Share on other sites
dc2r 0 Report post Posted June 8, 2007 Gidday are these hub centric to 51mm? They have a plastic locating ring that fits in the hole in the centre of the spacer and that locates on the hub.. if thats helps Quote Share this post Link to post Share on other sites
