dc2r
FS: 4X100 26MM Bolt on spacers
As above, have a set of 4 26mm Spacers in 4x100 stud pattern, in very good condition, minimal use, came off a e30. good if your after the mad rwd offset stz or allowing wider range of wheels to be fitted,. can be used on other 4x100 stud patterene'd cars.
$220
Edited by dc2r
$220
Give me a resonable offer and i may just take it
Gidday are these hub centric to 51mm?
They have a plastic locating ring that fits in the hole in the centre of the spacer and that locates on the hub.. if thats helps
