nzodea
Chassis code for m coupe
HI all:
new member:
I am looking to import a z3 m coupe from japan during this year. Specifically I am after a 2001 - 2002 s54 engined model.
I am haing problems finding the right vehicle code at the japanese auction houses.
CM32 - is the M coupe to 2001 (earlier S50 engine)
CN sereis are the z3 roadster after 2001
I can't find the Coupe!! I think it may be CL, but can not verify it.
Anyone able to help out.
thanks
Michael
HI all:
new member:
thanks
Michael
Z3 2.8 Coupe 1998-1999
Z3 3.0i Coupe 1999-2002
Z3 M3.2 S52 Coupe 1997-2000
Z3 M3.2 S54 Coupe 2000-2002
So the Z3 coupe with the S54 engine was made from 2000 to 2002 (Jan thru Dec)
CM32 probably means Coupr, M3.2 engine. So possibly applies to S52 and S54.
Get them to give you the VIN numbers then you can look up each car yourself and confirm what it is.
Jochen
Thanks for your help guys
Issue for me is the car auctions in Japan use a shrtened number. It appears to be the model type (i.e. CN) followed by the CC rating (i.e. 22) this is a Z3 roodster 2.2L
I did find this of use as well as the site
bmw vin code decoder
Still trying to find if there is a method to the japanese auction sites!
seems it could be CN, CM or CL 3.2
Guest Phil Ken Sebben
Z3 M COUPE, S50, Euro CM91
Z3 M COUPE, S50, Euro, RHD CM92
Z3 M COUPE, S54, Euro, CN91
Z3 M COUPE, S54, Euro, RHD, CN92
Thanks Phil Ken Sebben.
As a question what is the z3 M roadster, Euro, RHD?
Thanks again
Not a US spec one.
Euro and US spec are the same - CN91, and Euro RHD would be UK, NZ, Australia, Japan - CN92
Not a US spec one.
Thanks
I will be looking for a CN at the auction houses.
Thanks again
Top man, If you find a wrecked CN, let me know, as I'm pretty sure its the easiest way to S54 an E30 :D
