jpp 0 Report post Posted June 11, 2007 Panasonic CY-PA4003 1000W 4/3/2 CHANNELS AMPLIFIER Still boxed and wrapped etc. Cheapest identical model on TradeMe is $280, RRP: $349 I'm selling mine for $255. Perfect for running front components and a 12". "Intelligent" Bass Servo Circuit In comparison with the midrange and tweeter units, the woofer has a relatively higher moving mass, heavier voice coil and larger inductance, so it needs more current to start moving Products Spec: 1000W (250Wx4) Max 250W Continuous Output Power (64Wx4 into 4 Ohms, 20 Hz - 20 kHz @ THD < 1%) Typical Power in Bridged Mode: 225 W x 2 ([email protected] V) Adjustable Bass Boost Control 50Hz-250Hz Adjustable LPF and HPF (Crossover) for Front/Rear Easy Level Adjustment after Installation Mix Mode Operation (Bridgeable 4, 3 or 2 CH Operation) Switchable Input Model for High-Level & Low-Level Servo Drive Circuit for PWM DC-DC Converter Line-Out for another Amplifier Thermal Shutdown Protection Circuit Quote Share this post Link to post Share on other sites
