joel
oils
hey was wondering if anyone knows which grade oils 2 use in the diff and garebox in the old e28s?
lsd diff and manual, non dog leg box
thanx guys
Scrolling through the old threads here and finally found what grade oil 4 my diff, but still can’t find the correct gearbox oil, can any1 shed some light on this?
Thanks
My e28 handbook says SEA80 gear oil for the M535i and about 1.25 litres.
Go synthetic - Penrite, Amsoil, or Redline would be good choices.
Penrite is my personal favorite. Try the two links below too (although neither are synthetic).
http://www.penrite.com.au/html/s02_article...p;nav_top_id=55
http://www.castrol.com/castrol/productdeta...ntentId=6007785
FYI, diff oil is Hypoid gear oil SEA90. Make sure its LSD oil!!! About 1.9 litres.
Good luck.
Good luck.
thanx 4 that :)
just one question, is sea90 diff oil the same as 75w90 which i read in another topic?
No its not.
You probably wont do any harm using that grade but in this climate its not really necessary.
Its not hard to find 90 LSD oil. Supercheap auto stock both Castrol and Valvoline in that grade. Or you go into BNT automotive (do they have on in HB?) and get some Redline. Thats what I'd do anyway. You dont need too much and you don't replace it that often so I'd say go for some good stuff.
If you do need anymore help, feel free to PM me.
Cheers.
No its not.
Cheers.
thanx 4 your help, ill go back there 2moro (bnt)
cheers
