Guest SeelanNaidoo
e30 crankshaft
Guest SeelanNaidoo
Hi Guys..
Anybody in need of a 327 crankshaft.
This is the really billet crankshaft for 327.
Guest Spargo
the 325td is the one you're after, but i've never seen a diesel E30 in NZ. Ever. Also, the one from the 525td is better aparently.
Note that if you're turboing, the failure rate is about the same for cast and forged cranks.
Guest Spargo
Ah, a re read was in order.
How much do you want for it? I'm well keen.
yeah....2.7 builds are bloody hard to do as we dont have any near as many e's as the overseas guys...this one of the only options.....andrew could possibly be keen...ill let you know
Guest Speedye30
A Billet crankshaft?? That's about the most expensive way to manufacture a crankshaft!! How much are these things new? How much do you want for yours?
Guest SeelanNaidoo
sorry for the wrong choice of word.
it's not an aftermaket billet crank.Just the original(balanced) from a 2.7is. I think I have a stage one camshaft also(not sure what degree it is)
plently of E28 528e & 525e's around!!!
hmm.....must all be down your way because i never see em here in auckland.....none of the wreckers have them either (localish wreckers that is)
Guest Andrew
Hi - i'll take it provided its in good nick. When is good for you for me to see it and talk $$
Guest SeelanNaidoo
i am a bit full up this w/end .
how about sometime next week. mail me for details
Guest Andrew
Early as next week please. I'll get back to you
Guest Andrew
does the cam fit a 325? :wacko: if so would it be any better than the stock and wat sort of $$ are u looking for
Its a crank.
I don't want anymore - just got my 325 crank lightened and balanced ($$$$) so i'll be using that in my motor build.
SeelanNaidoo Posted on May 7 2004, 09:42 AM
Guest SeelanNaidoo
crank is sold .
camshaft for sale 282degree for 12 valve 325 , 327
