dickhead 0 Report post Posted June 15, 2007 (edited) http://www.trademe.co.nz/Trade-Me-Motors/C...n-103900095.htm im real interested in getting this and gettin a mechanic to install it. to my 1995 320i is there anything i should know? anyone got a ballpark figure $$ wise when its been programmed into ecu, with intercooler etc? Edited June 15, 2007 by loose36 Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted June 15, 2007 Check quality of the components. Personally I wouldn't buy a 'kit' like that as you just know its come straight from China and will be shiat. Wait, since he has 'more' for some other sucker to buy and install, if it works, check it out again, otherwise I'd wait. It's only been on for a week or two ae,. Quote Share this post Link to post Share on other sites
PBOY23 0 Report post Posted June 15, 2007 (edited) http://www.trademe.co.nz/Trade-Me-Motors/C...n-103900095.htm im real interested in getting this and gettin a mechanic to install it. to my 1995 320i is there anything i should know? anyone got a ballpark figure $$ wise when its been programmed into ecu, with intercooler etc? yeh there is alot of work in doing this i looked into it for my e36 the guy sounds pretty genuine as im getting him to put halos in the head lights, ill look at the kit at the same time but yeh abit suspect about the manifold you would be better off with the one from driven perfomance listing on TM also that intercooler might be a bit big also you would have to run a piggyback ecu of somesort but at the end of the day its up 2 you and you budjet cheack out this web site gives a really good indication of what works involved http://www.ca-automotive.co.uk/products.ph...&comp_id=14 Edited June 15, 2007 by PBOY Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted July 2, 2007 Yes as JP said be very careful when buying kits from TradeMe etc.. I Bought one about two years ago for my 89 DA6 Integra no doubt it went hard but as far as quality goes the manifold craked in so many places. Everything else was pretty legit i know the turbo was a cheapy it also decided to fail on me after about 8 months but that could have been a number of things. End of day do your research i would put together my own kit and spend the money, doing it cheap at the end of the day ends up costing you more than its worth. Quote Share this post Link to post Share on other sites
