Gus
Rear Shock Mounts
on a lotta peoples mod lists they list e46 m3 vert rear shock mounts....what is the benefit of using them?
Guest Spargo
Much stronger, as they have to carry more weight (vert shell is heavier)
Seeing as the rear suspension in an E46 is coilover, it has to carry more tensile strength, whereas the E30 has 2 points to carry the same load, due to the independent suspension design.
So therefore the E36 vert RSM is the way to go!
