rxsumo
16 inch BBS RS for 5 Series
I brought a set of BBS RS's a while back, but we have discovered that one of the rear ones has developed a crack on the inner rim section.
So what I'm after is a single rear BBS RS for a 5/7 series.
If you have a partial set will consider buying the set. Will also look at buying a damaged rim to get a good inner.
PM if you can assist
