323e30
are manual 323 and 318 flywheels the same?
will my 323 clutch and fly wheel fit a 318i engine? both manual boxes but 318i hasnt got a manual flywheel or clutch or pressure plate.
Short answer, no.
318i will use a 215mm pressure plate while the 323i will be a 228mm. Some of the early M10s shared a flywheel with the 6 cyls though so they should be interchangable.
