Jaredsc
E36 Climate control unit
Hi, driving home tonight, just got out of work's carpark when suddenly the climate control display
starts flickering also accompanying this, the noise like a vent trying to shut somewhere in the dash
and each time it flickered you could hear the noise. Sort of like something opening/closing, then the thing went blank completely, was very worried at this point as no air was coming out of vents as well, so i turned the fan speed button right off to turn the unit off, then back on again and it worked!
Anyone know whats goin on here? Note also I had rear demister on and couldnt turn it off while this happened, its orange light was still on though. :unsure:
control unit is playing up .Remove strip down and resolder cracked solder joints then refit.Bobs your uncle and fannys a rude word
My symptom was system display showing on but no air coming out of the vents.
No flickering though.
Followed this site's instruction and all ok after that.
Edit: typo
Edited by my_e36
Thanks for the link to that article, but I already had it fixed. I took it to a BMW mechanic in Wairau Rd
North shore (where I live) and they replaced a resistor, cost $250 for 3 hours labour and the resistor.
