pureboiracer
intake manifold
would something like a 535i intake manifold ant throttle body fit onto a pfl 325i block? and would it use origianal injectors or would i have to get new ones?
Only if it came from an M20 engine,this has been done down here in Christchurch,the manifold and throttle body complete.This is a good performance mod as the length of the manifold runner is alot longer,giving more low down torque response.You will have to modify the manifold intake ports to match the gasket size and by the way don't pay any more than $20.00 dollars for the manifold as they are only worth scrap metal price.
will i have to grind out the ports in the head to match the manifold? is it a fairly simple job or will i have to do like 10 jobs to get that one to work?
